krb1991
amp recommened for sundown sd2 10
Whats a good amp for 500 rms at 2ohms just got big three done and stock alt in single cab. I may just be a noob but ia it better to run at 2 ohms rathrr than 1 to not tax the hell out of my electric
Either load will be fine. 500 RMS is not that much power, so you should be fine.
Ok thanks guys also u think that knu 4guage amp kit is shit? Or what should i buy 4 guage thats not too expensive
Was lookin into the rockford fosgate primr amp says runs a good 500 rms at 2ohms. Are class a/b any good?
No, you will want to get a class D mono block for a subwoofer amplifier.
Could you elaborate on this for the op please?
A class a/b amp will work just fine for a subwoofer
Depending on you budget, this is a good option.
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/8245014/vpcsid/0/SFV/30046
Also check out the SSA store.
x2
Class D amps are smaller and more efficient which makes them good choices for a sub amp, BUT at 500 watts RMS you shouldn't notice any drag on your electrical, especially since you have had the big 3 done. I have really enjoyed and been impressed with my Boston amp, might want to try this...http://www.sonicelectronix.com/item_17785_Boston-Acoustics-GT-2125.html
Edited by SS Teacher
The rockford fosgate prime amp is ab does 500 at two ohms is only 130. Seems like a good price what do you guys think?
Sorry never dealt with two channels could i wire one sub and get thr full 600 rms?
Yes you can.
Ok thanks i will give that amp a try for sure since u recommend it;) what type of amp kit would u also recommend
Also for that amp should i get d2 d4 sub to get full 600 rms not much info listrd on it
If you are getting one sub get the d4 an wire it like this
One to each channel or both to one channel
If you look at this pic you can see that it says mono and points to the outside inputs. Put the positive in the positive and the negative in the negative.
You have been a great help thanks for your knowledge. One last thing if u dont mind what amp kit should i get? Not to spend too too much would be nice
You don't need anything crazy, 8 gauge will do but I would probably use 4.
No problem! I use that amp for my front stage and really like it.
Yeah i was gonna uae 4 but i mean what amp kiy. What brand?
