basshead7890
Sundown Saz-1500d v2 and Xcon 18 D2
1. Product:
Sundown SAZ-1500Dv.2
2. Specs: Rated power output
----RMS power, 2 ohm linkable/dual mono 3000W x 1CH
----RMS power, 1 ohm mono 1500W x 1CH ----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono 400W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm <0.1% Efficiency @ 4 ohm 86% Fuse rating 40A x 4 Input Sensitivity 200mV to 6V (+/- 5%) Dimensions 252(W) x 58(H) x 434(L)mm
3. Description/Condition:
Has a couple of scratches, about a 8/10 cosmetically, Mechanically 10/10. Amp includes original box as well as bass knob.
Bought it, but now I have decided to go a different route.
4. Price: :
$325 shipped
No trades
5. Pictures:
** DO NOT DELETE ANYTHING BELOW THIS LINE OR THREAD WILL BE DELETED **
This message is automatically inserted in all classified threads.
Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
1) Telephone number. Call the number back at a unspecified time and make sure that it is the person's correct phone number.
2) Name and address including postal code
3) Valid e-mail address. Send an e-mail requesting a response to information about the deal being made.
DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
If transaction was completed on ****, please use iTrader to record feedback.
Potential buyers/seller should check iTrader feedback also before continuing transaction.
Edited by marq7890
9/10 Cosmetic 9/10 Mechanical
Coil is a little dark
It's the 1st version with the pole vent
4. Price: :
$325 Shipped in original box
no trades
5. Pictures:
Edited by marq7890
Would jump on it if you had two. Good luck selling budddy. Bump bump
Good luck with sell. Are you stepping up to zcons?
