mnapoleon
Suggestions
Hi guys, I want to share with you my future setup and wanted to know if the stock electrical will be able to handle it: I am brand new at this car audio business
I crescendo 3500D at 2 ohm -- 1900 W continuous power
1 FI BTL N2 12 running at 2 ohm
1 4 channel JBL 100 W rms each channel
4 jbl 6.5
1 Pioneer 9400
Box tuned to 32 Hz (got the cut sheets from BTL forums)
I will be doing the Big 3
I have a 2004 Accord with stock alternator approx. 100 Amps and yellow top optima
Thanks guys
Suggestion. Don't use a black font. Most of us use a black background. And as for your answer, that is up to you. If you listen to Kenny G all day it'll be fine, but that doesn't mean carte blanche it'll be fine. And no, if you are burping a continuous 1900w while driving down the street it won't even come close.
Sorry about the background. This will be daily option and cooling, volume turned turned up maybe a quarter of the way on the head unit. Ill be using for listening to rap maybe a little bit of rock.
I read somewhere that if the electrical of the car is not capable, it may lead to clipping? is that true
Edited by mnapoleon
