Recently Browsing 0 members
Recent Topics
- 7 comments
- 330 views
- 1 comment
- 405 views
- 1 comment
- 161 views
- 1 comment
- 148 views
- 3 comments
- 1,006 views
- 8 comments
- 1,920 views
Similar Content
By Shogen
Parting with my beloved 80PRS .... Don't really want to see her go but I'm not one to waste amazing hardware
SOLD
PayPal verified only ...
Unit is in great condition. Comes with bluetooth mic and TA mic. Also has wiring harness and remote plus faceplate case
Photos below (sorry if not great but taken with iphone 7 plus aka my next listing)
By Shogen
Like the title says.... Getting rid of this bad boy, has all accessories (even the GPS antenna) except USB wire which you can pick up any where (USB extension cable).... I will let this go for $675 shipped....
Price: $675
PAYPAL ONLY
Shipping within continental US only
***MODs I took photo last night but had issues getting onto the PC hope yesterday date ok***
Buy with confidence, long time member of the community...
By rmksledhead
Figured I should start a build log since I've gone through so much trial and error in getting this stereo to sound good.
I'm already done with most things but I did take pictures along the way so i'll get that all uploaded when i get photobucket or imgur figured out.
I bought my passat almost a year ago, the weekend after black Friday to be exact, and knew immediately that it needed some love in the bass department.
I had a rockford p-300-12 powered enclosure lying around that i once had mounted in a big self-propelled sprayer that i basically lived in for 3 summers, threw that in along with a rockford loc, rockford rca's, and some ebay 4ga cca to get it powered.
That sounded awesome for the average non-basshead and would suffice until i found a real solution....
Did some searching and found this great place! After searching and reading here for hours I decided on a Fi BL 12 for a sub and a BRZ1200.1 hifonics amp to power it since i'm a poor college student and can't afford a bc, aq or saz lol
I built a vented box for the BL that was 2.68ft^3 tuned to 28.5hz
After I finished the box I had to stuff foam above the headliner near the upper brake light and under the rear deck to stop some rattling. Installed some dampener (dynamat and ebay stuff) to the trunk lid, under the trunk carpet on the floor, and rear deck from inside the trunk. dampener helped a ton.
After the substage I realized that the stock front stage was not going to cut it... I knew that I wanted to fill some of the lacking upper bass frequencies with some volume so I was looking for the biggest components I could get for a decent price. Ended up getting the xr1800p components from Kenwood. They've got a big 7" woofer and an oversized 1 3/16" tweeter with external crossovers. currently the set is being powered by a dusty old pioneer 4-channel amp GM-x524. I'm not perfectly satisfied with the front stage for now since the amp likes to protect at high volumes and I've got some fuzzy distortion from the tweeters in certain frequencies. once i change the amp to the GM-d8604 class d 4-channel from pioneer I think it will get much better as I have the older GM-d9500f version in my s10 that never protects and has no distortion until extreme volume.
also ran another 4ga run of cca to the trunk and a distribution block when I added the second amp.
Also changed out the stock HU for a Pioneer Avh2600bt touchscreen unit which is fantastic for the money.
I decided that the box was tuned too low so I chopped 10.5" off the port giving me a 2.88ft^3 net volume tuned to 32.2hz and was much happier!
Now for the real reason I'm starting this build log.. I'm going to try a 6th order bandpass to keep this 'new to me' low end rumble and get back the awesome upper frequency volume from my mtx square sub in my s10 for when i want to blast the 50hz Flux Pavilion bass cannon!
Much more to follow, including pics for the above^ stuff!
By spanky1975
I am trying to run the auto-eq on my unit. I keep getting an error message for outside noise.
I am running in 3-way active mode. Internal amp is turned off. I did reset the head unit and tried again and still had the same error. I am performing the auto-eq in a very quiet closed garage.
Any suggestions or help is greatly appreciated.
Recent YouTube Posts
