21 members have voted
  1. 1. what amp would you choose
    • sundown NS1
      11
    • digital designs z-se
      10
im stuck... help me.
both 1 ohm daily .25 burps. on 300 mechman and 3 dekas
Edited by bigjon
You've been sundown for as long as I can remember. Why change now?
J
Which one is cheaper?
dd
J
thats why its hard for me
foot print is an issue....... and well...... thats about it really.
i choose NS-1
Crossfire 8k
J
How much is the difference in footprint, dependable output, and pricing?
J
DD Dimensions - inches 30L x 11.9W x 2.8H
sundown Dimensions 12.20"(W) X 2.68"(H) X 27.56"(L)
sundown NS1
RESULTS:
starting voltage 14.8v
voltage drop 12.7v
wired to .5ohm rising to 1.39ohm @ 45hz
rail voltage 97.3vac
amperage 70amp
total output = 6811w
i keep finding, this in refrance to the DD
2. Specs: Easily a 7k amp
7,600w @ 14.4 volts
9,000w @ 16 volts
and i talked to 1 person that said he clamped it .. he said 6600 watts @ [email protected] volts starting ohm load at was .67ohms.
DD amp is a amp that will appreciate. The NS-1 will not.
I believe the Z will also do more power, and run .25ohm more stably then the NS-1.
dd
Winner.
dd
Winner.
please vote sir
DD,.... sometimes change is good, on the brighter side you can always change again smile.png
Sounds like speculation to me.
I voted Sundown because of the customer service, but I would seriously look at the new Crossfire amp. It would outperform both amps listed and I hear they have incredible customer service too.
I vote sundown. I've seen those dd amps in action. At low impedance they are very sensitive to low voltage situations. I haven't seen the sundown NS-1 in action, but I did see how your 4500 performed, and itfthat's any indicator of how the NS-1 will perform, I'd stick with the sundown. :P
A trunk load of the old Orion 2500D's. ;)
they put up a 160 with the truck off, so 12 volts at the ellis reed show. i was shocked.
but with there only being 50 made there are not many details and test results. :(
why only 3 dekas?
thats what i have as of now.. i plan to add 1 more.. but thats pretty much it.
i vote you add more battery.. it takes power to make power....
:o it does?
ohmy.png it does?
:lol:
