Will a set of Dcon 15'' in a 6cf box tuned to 35hz with 90in of port on a audiopipe 1500.1 work are is that amp 2much for them. and how long b4 the Dcon are in stock..
That is honestly a bit too much power for the Dcon's if you plan to run the amplifier wired to 1 ohm mono. I would suggest moving up to the Gcon's if you plan to go with 1ohm on the amplifier. We have a few Dcon 15's, we just have to update the SSA Store.
I had a set of sundown E15' on the amp in that box and it did real good and got loud. just sold the E15 and was looking to try something new in my setup. so are you telling me the Dcon wont take the power like the sundown E15' did.
Not sure what load you had the sundowns on, but the Dcon's should take the power. BUT!!!!! as a smart company, we are not going to suggest running more then double the rms, then have a world of people cooking their sub woofers and complaining about warranty coverage because I said it should take more then double the power. We like to keep our doors open and stick to suggested rattings. You are going to see very little gain on any sub woofer for daily driving pushing them way past rms ratting. What you will see is a shortened life span.
