d luv
Completely Lost is all that comes to mind!!!
I have a 1999 Buick Park Avenue and am getting ready to purchase the things that I am still missing in my setup. My main concern is my Audiobahn 2300hct powering my 2 12" JL W7's at 1ohm. I have a yellow top for the trunk and a capacitor as well, here is where I'm lost as I've never used an extra battery or a cap before. The AB has 4x40 fuses, and I also plan to buy a 4 channel amp that does 75x4 rms {not sure on model yet}. My first question is how many fuses should I run throughout setup? Currently I have a 200amp ANL fuse, should I run this 18" from the battery {front duralast, or trunk yellow top}, or should I run a 200amp ANL at each battery?
I Also plan on purchasing a distribution block, should this be fused? If so how big of a fuse for the AB output, how big for the 4 channel output? Should the capacitor be fused also? Should I upgrade the big 3 to 1/0 gauged as well? The wire I am looking to buy is http://www.wireandsupply.com/product_p/sgx-1-fslash-0-fslash-01.htm , will this do or should I step up to http://www.wireandsupply.com/product_p/sgx-2-fslash-0-fslash-01.htm ? I am sorry for the lengthy post but I am really confused, even more confused than you after reading this frantic post. Thanks again for the help everyone.
Purchase List
High output Alt- Is 200amp enough or should I go bigger?
Power/Ground Wire
Fuses
Wire Connectors
Distribution Block
Get rid of the capacitor. Its basically useless and will just cause more confusion.
I Also plan on purchasing a distribution block, should this be fused? If so how big of a fuse for the AB output, how big for the 4 channel output? Should the capacitor be fused also? Should I upgrade the big 3 to 1/0 gauged as well? The wire I am looking to buy is http://www.wireandsu...0-fslash-01.htm , will this do or should I step up to http://www.wireandsu...0-fslash-01.htm ? I am sorry for the lengthy post but I am really confused, even more confused than you after reading this frantic post. Thanks again for the help everyone.
Purchase List
Power/Ground Wire
Fuses
Wire Connectors
Distribution Block
Hello and :WELCOME: Here are MY answers for the questions you have asked and are IMO.
  • My first question is how many fuses should I run throughout setup? No fuse from batt to batt, you can if you'd like for extra safety, Also, if not already, I would recommend matching batteries. You will then want to fuse from batt to amp(s). If you are going to use a D-block, you want to fuse both leads from DB that Distrubute to the amp(s). So that will be 3 fuses in my setup.
  • should I run this 18" from the battery {front duralast, or trunk yellow top}, or should I run a 200amp ANL at each battery? answered above
  • distribution block, should this be fused? Answered above
  • If so how big of a fuse for the AB output, how big for the 4 channel output? Check for manufactures specs
  • Should the capacitor be fused also? Remove Cap
  • Should I upgrade the big 3 to 1/0 gauged as well? yes
  • The wire I am looking to buy is http://www.wireandsu...0-fslash-01.htm , will this do or should I step up to http://www.wireandsu...0-fslash-01.htm ? I would recommend visiting weldingsupply.com, if your on a budget, I would ebay any 0gauge wire kit.
  • High output Alt- Is 200amp enough or should I go bigger? For your equipment, yes, if you are going to upgrade your system in the future, I would recommend buying the most of what you can afford. Take a look at mechman/dc-alt(not a fan)/singer alternator/ohio generators
    Power/Ground Wire weldingsupply.com (search "cable")
    Fuses I have always like the fuses that come with AudioPipe equipment
    Wire Connectors Take a few looks at this thread
    Distribution Block Darvex.com has some nice ones
Hopes that helps man. LMK if you have any other questions
Senchez kicked my ass with that post. Way to make me look lazy. :D
:lol::wub: !!
1.5 ohm, they are 3ohm coils
Haven't heard from you since your first post, was just making sure I was clear, or was there any update on your scenerio.
and that amp will not run them subs good at all u need at least 2k at 2ohm BTW and then u will more than likely need to up ur electrical again
No you were very clear and helpful TY. I am currently in the process of ordering a 250amp alt from Singer, then im ready to install. I know the Audiobahn is not perfect for the W7's, but it will have to do until I get some extra cash. Im hoping to get atleast 1600rms at 1.5ohm but im just hoping. Everyone trashes it, but I heard it on 3 12" JLw6V2's and it pounded and sounded good so who knows? I just got it cause it was only used for a week or two and I couldnt pass it up for the price. You guys have all helped alot with your input.
    1. Recent Topics
        • 1 comment
        • 46 views
        • 1 comment
        • 36 views
        • 1 comment
        • 42 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 892 views
        • 8 comments
        • 1,815 views
        • 1 comment
        • 79 views
  • Similar Content
    • By Godsmack
      - 27 Raptor 1/0 AWG Ring Terminals $20
      - Install Edge 5 pack remote wires [IEC P 3x5-6] 6 feet $15
       - 2 packs Install Edge 6.6 ft RCA cables [IRC GAC2] $7 each or $10 for both
       - 8 4 way Knu Konceptz 1/0AWG in 4 8AWG out $8 each or all for $55
       - 50ft 16AWG speaker cable spool $5
      - Install Edge Remote wire [IEC P18 X5-6] 18AWG $5
      - Knu Konceptz kolossus Flex 1/0 AWG Red power cable 44 ft $125; 8ft $25; 10.5ft $35 (all for 175)
       - 13 ft Q power 1/0 AWG Super Flex on spool $25; 15ft on spool $30
      - Approx 400 ft 16AWG Q power speaker wire on spool $40
       - Stinger 150 amp circuit breaker $25
      - 6 Install Edge Speaker Savers [IEC CAP 133] $6 per pack or all 6 pairs for $30
       - 2 2packs Rockford Fosgate 8AWG Ring Terminals $5 each or both for $7.50 -
       2 Rockford Fosgate Side mount battery terminals $9 each or both for $15 -
       Rockford Fosgate 2 output top mount battery terminal $10
      - Rockford Fosgate RCA coupler $5
      - Rockford Fosgate 10 AWG Amp kit (no RCA wires) 17 ft $30
       - Rockford Fosgate pack of 2 100amp MAXI fuses $10
       - Knu Konceptz Negative top mount terminal $10 -
      Metra Honda Harness [BB-WHHDI] $10 -
       Metra Inpala/Monte Carlo [XSVI-2105] $35 - Metra GM 88-05 22 pin harness [70-1858] $5
      - Pair of Dynex square box terminal cups $2
       - Dynex OEM Ford Radio removal tools $8
      - Stinger Blue HPM voltage meter [SVMB] $15
      - Tsunami Marine ANL fused distro, 1/0 AWG IN, 2 1/0AWG out $20
       - Generic ANL fuse holder, no cover $5 -
       Mini RCA stereo Y cable $2 - 14ft Raptor RCA cable $10
      - 16 ft Monster RCA cable $20 -
       Stinger 1/0 AWG ring terminal $4 -
       2 2male 1female RCA adapter $5 each or both for $7.50
      - 1 RCA to RCA dual male wire 9" $2 -
       2 Street wires RCA cables in bags 19.69 ft [ZN1260] $7.50 each or both for $10 -
       ANL fuses, 2 200amp, 4 250 amp, 2 300 amp, 4 100 amp, 2 500 amp. 500 amp are $5 per pair others are $3 per pair, or all for $30
      Total price when purchased individually: $761 Buy the whole lot: $650
      Open to trades, Nikon FX lenses and other photography equipment are of special interest. Feel free to contact with questions. Thanks for looking!!
      - Viper 500.4, missing xo cover, and right mounting feet. $300
      - MTX Road Thunder XO's for componants. $20 for the pair
      - Eclipse SC-8355/8365 XO's for componants $50 for the paid
      - Phoenix Gold Octane 4.0 2 amp. $150
      - JL Audio 500/1. Missing some side screws. Not 100% on what the guts condition is, and last I remember looking it was fine. $125
      - Digital Designs DD C1. $140
      ORIGINAL RE XXX 12" to come, as well as more amps. I'd love to sell everything as a lot, and am willing to make deals. Only thing trade wise I would be after is Nikon FX lenses, but feel free to offer up. Pics are all on the link below.
    • By DedicatedEnthusiast
      Crescendo BC3500D is approximately six months old, has never been exposed to low voltage and has no scratches, dings or dents whatsoever. Does 3,875 watts RMS at 13.8v
      Xs power XP3000 battery is sitting at over 12.7v after being out of my car for several weeks now and is rated to support 3,000 watts rms power
      2/0 welding wire is rated to support over 400 continuous amps of current and has already been heat-shrinked and fused for both positive and negative runs from front to back plus the big three upgrade and an additional trunk ground if you so wish to use it
      WIRE CAN BE HAD FOR  $120 SHIPPED FORGOT TO PUT PRICE AMONG OTHER INFO ON SALES SHEET
      So i've seen several differing opinions on this was jw what the correct thing to do is now days when dealing with 12v xs power batteries such as the d5100R
  • Recent YouTube Posts
