JohnHinerman
volume and tunning??
Anyone be able to give me an idea of what this enclosure may be tuned to??
I have a picture and a sketch with the measurements I took. The bottom right drawing is the port. It is shaped like an L, and above that I was trying to show that it is 16" in height.
Any help would be great. Just trying to get a rough idea of what this enclosure is all about. It a "Turbo Vent" enclosure, could not find anything on the internet about them.
If I did it right, it should be about 40.5hz??
Impedance is highest at enclosure tuning. Therefore you could play a set of test tones, and measure the voltage at the amplifier's speaker terminals for each frequency with a dmm. Where ever the voltage is lowest, impedance is highest, and that's your enclosure tuning frequency.
*The speaker will not be disconnected for testing.
*There is no reason to play it loud for testing, I would do it at relatively low volume.
If you don't have any test tones, say so, and I can provide a link.
See below post.
Edited by stefanhinote
Impedance is not highest at tuning. There are two peaks one above and one below tuning. The impedance graph would look something like this (Blue Line) for a ported enclosure, this one is tuned to about 31hz.
OP, I have that enclosure figured at about 0.94ft^3 @ 44hz after port and driver displacement.
Stefanhinote, my measurements are internal measurements, (inside the box, the port walls act as the internal walls. I calculated about 2.12 ct foot for the enclosure, and port volume of .64 cu foot
Am I doing something wrong??
So not including the woofer (not sure how much volume it takes up) I'm coming up with ~38hz tuning. There is also about 2lbs of poly fill in it.
I'm not sure what the woofer displacement is, but
