ExclusiveRA
Sub box
I want to build a box for my 2 12's. I want it to be ported but I'm having a really hard time finding a diagram or blue print. The recommended enclosure according to the website is .5 to 1 cu ft. Kinda confused as to what that means.
Please provide more information. You haven't even stated what subs you have.
Never worked with those subs so I had to look it up. Especially since the cuft you listed seems small for a ported 12.
I found the manual and it actually lists it as 1.2 cuft recommended.
That means you need 2.4 cuft net for enclosure volume. It also suggests using 2 3" ports. Then you will need to cut to length to tune it to the frequency you want.
Here is an enclosure building program, a free download. It's what I always use.
Play around with the measurements and ports to get the size you need that will fit in the space you have.
https://skydrive.live.com/?cid=1e28f7d3956a626f&uc=1&id=1E28F7D3956A626F%21102
