SMpaintball78
how do i strap these bishes?!?!?!
welp finally got my hands on a second aq2200 wink.png now the only thing is i hyave no idea how to strap them together!!! lol iv never done any kind of strapping what so ever so help is appreciated!
subs are d2's by the way. i have 2 sets of power and grounds in back as well.
sexynesssssssss
Edited by Lantz
For each sub, wire one voice coil's positive to the other voice coil's negative.
Wire the two remaining positives to the positive of the master amp.
Wire the two remaining negatives to the positive of the slave amp.
Wire the speaker terminal grounds of the master to the slave amp.
Run your RCA cable to the master amp.
Run your bass knob to the master amp.
Run a short RCA from the master amp to the slave amp.
Flip the Master amp to Master and the Slave amp to Slave.
Tune the Master amp.
your going to need more then 1 deka and 1 red top.
Definitely.
This is from the sundown site
The master amplifier gets the input from the head-unit and a mono RCA from "BR Out" connected. The slave amplifier ONLY gets "BR In" connected from the master. ALL controls are handled on the master, setting anything on the slave is not necessary.
This picture should be pretty self explanatory.
* The slave takes the "-" connection(s)
* The master takes the "+" connection(s)
* The "-" terminals of the amps are hooked together.
You don't need to use both sets of "+" on the amps. They are there for flexibility. While you should always connect both "-" terminals on the amps together using large wire as general procedure it is not absolutely necessary to use both sets of "+" terminals. They are connected together internally in parallel.
Definitely.
i have some batteries in the works :)
here is 2 aq2200's cant i just do this? lol looks alot less messy
I don't know shit about strapping, but are those amps seriously zip tied together?
I know that's not your pic either...I was just wondering.
haha yes they are
that's how its done. Only they have one set of speaker wires.
You could always look in a owners manual too.
1.speaker negative on amp 1 to speaker negative on amp 2
2.amp 1 positive to sub positive (master)
3.amp 2 positive to sub negative (slave)
4.all settings on master amp
5.all settings on slave amp all the way down
6.subwoofer cable to connect the amps (will be a single RCA jack)
7.main RCAs into master amp
