blanca87
sa-8v2 enclosure in metric and littles
hi i got 2 sa-8 subs and im gona make 1.6 Cubic Feet = 45.3Liters enclosure
but i dont know about port
can you help to get calculations right with square port
Are you asking about port area?
y 1.6 cubes the subs only need .5 each? if you do a box that is 24" wide 16" high and 12" deep with a 12" long port that is 1.5" wide and 32" deep (wrap it around the box) you will be tuned to 31-32 hertz which is the recommened spec for these subs
sry.. i was hasty with that first post... so now i make things easier i hope..
i mean that i want port in metric system.. because its hard to me keep up with ft3 and inches..
and then i founded to hard realize what this mean in metric and littres "Minimum Area = 45.8 inches" when i used this link to calculate minimum port.
got 2 sa-8v2 yesterday so its time to make good enclosure plan.
