twinkie7238
2 - SA-8v1 Box help
Vehicle: 1992 Ford Festiva
System setup: 2 layers of peel and seal on the roof, hatch and entire cargo area from bpillars back... 160 amp ohio gen alternator, 950cca optima red top up front, xs 450cca in the rear... big 3 with accel 2 guage power and grounds....head unit - jvc-kd-avx2.... amplifier - atomic 1000.1....american bass 4" coax (front and rear).... subs - 2 sundown sa8d2 version1's
Space to work with in hatch area:: 35" wide 12"deep 16"high
material: 1" NOVA PLY
goal: MECA Street 1/ 142-145 @ the headrest
Car peaks out at 50 hz with mic on passenger seat, drivers door open, passenger door closed, woofer on passenger side, port on driver side, woofers and port facing up??? seem to lose a db or 2 with port facing drivers quarter panel and woofers facing up...
can anyone give me ideas on box size before or after displacement, would like to tune box between 40-45 hz
Edited by kinzynryder
