Recently Browsing 0 members
Recent Topics
- 7 comments
- 469 views
- 1 comment
- 680 views
- 1 comment
- 234 views
- 3 comments
- 1,113 views
- 8 comments
- 2,040 views
- 1 comment
- 193 views
Similar Content
By Ashy7
Hi guys I'm new to the forum and this is my first post. I just started out building my own boxes for the past 2 years now and need some assistance on this new build. Attached is the pictures of the box in progress. Can anyone assist me with port tuning (I'm from south africa so in cm would be great). The dimensions are :
Height 41.5cm
Length 90.5cm
Width 45.5cm
Sub mounting height 17cm
All wood is 20mm plywood
What is my current port tuned at
52.5cm port running in an L shape in the box
5.4cm width
Length 41.5cm
pictures attached
The sub mounting height is basically the walls around it. Thanks for the time
By dbdog
Hi Guys,
Hope you are all well and i aslo hope that some one can assist me with working out the correct spec for a true SPL box. please note I will only be doing SPL with this box.
Ok so I have 18mm ply wood, 1 12inch subwoofer, 1 amplifier and 1 battery.
Here's what i'd like to do
Get a minimum of 151db's from this setup
Equipment
DD Z1a
NSB 170 12v
Targa TG301-DW
The sub specs are as follows and i could be wrong because this is taken directly from the site.
12" COMP SUBWOOFER - DUAL 1
SPECIFICATIONS Fs (free air resonance): 48.7 Hz SPL (efficiency, 1W/1M): 89 dB Nominal Inpedance: 1/2 Ω Qts (total speaker "Q"): 0.606 Qes (electrical "Q"): 0.732 Qms (mechanical "Q"): 3.517 Vas (equivalent compliance): 20.84 L Mounting Depth: 195 mm Mounting Hole Diameter: 300 mm RMS (Watts): 2 x 1500W RMS
My Vehicle
Opel Corsa Lite +
Resonant Frequency 54Hz
Current Box
Box Properties
Name:
Type: Vented Box w/ Active HP Filter
Shape: Pyramid, truncated
Vb = 101.9 liters
Fb = 53.99 Hz
Fill = none
No. of Vents = 1
Vent shape = round
Vent ends = two flared
Dv = 247.9 mm
Lv = 290 mm
I would like to go slot port, i would like to increase on my number and i have already done the Big 3, deadening, and alternator upgrade.
Your help will be more than appreciated
Thank you and enjoy.
Recent YouTube Posts
