Recently Browsing 0 members
Recent Topics
- 7 comments
- 332 views
- 1 comment
- 414 views
- 1 comment
- 167 views
- 1 comment
- 150 views
- 3 comments
- 1,010 views
- 8 comments
- 1,925 views
Similar Content
By akaak
I’m trying to see if someone can answer this question for me in simple terms. Basically I want to know what is going to happen to my signal as it’s going to be transferred and how multiple equalizers, crossovers, and gains will affect it. So basically, my head unit has a built in equalizer and crossover (they’re not that great though.) From my head unit the signal will go to an external equalizer I have. From the equalizer the signal is going to go into a stetsom 3way 6 channel crossover. The crossover is a crossover (obviously). From the stetsom crossover the signal will go into my full range amps. I have 2 amps, one for mids and one for highs.
Now to make things even more confusing the crossover has individual gain knobs and so do the amps. Both of those amps have crossovers on them too. So how will the crossovers affect the crossovers when the signal transfers from one device to the other? And how about the equalizers? My guess would be to keep the crossover and equalizer settings flat on the head unit. Use the external eq for eq. Now the confusing part is I don’t know how the crossovers act with eachother. Does one fine tune the other? Should you try to match them? I hope this makes sense. If someone could help that would be great lol and yes I tried google
By Mtxplod
So i purchased a stetsom 7KD and I am curious what the external fuse rating is. i looked up the manual online but it only has info for the two ohm version. The one i purchased is the one ohm 12 volt version.
Also when i install this amp I will add another battery or two to what i have.I have noticed that a lot of setups have unfused connections on their terminals. As of now i have two batteries with two fuses 12 inches from each terminal. so if i install a third would i need another two fuses or would that only be necessary if they were a certain distance apart?
And of course when i do the install i will do another positive run and dual input terminals.
Thanks
Recent YouTube Posts
