Dangrebel
Eclipse titanium 12's
Well I'm bout to run 2 12" titaniums in my house for my boom box. But I will run them in my truck until I get my new wall built. Anybody heard bad things about these? I know about the surround issue but anything else?
Overall good drivers. TC 3HP motor. The surround is retarded huge which decreases cone area, assuming they're the SW91XX drivers. Definitely ported enclosure drivers.
Would probably do fine in a house for music.
Yup the sw9122 series. I think I'll pick up a 1000 watt plate amp sonetime soon. :) anybody ran these?
i have run them alot, and still have a 12", and a few 15"
if you really want to get them moving they need about 1500rms each.
and on the extreme side i have ran over 2krms each .
good driver, just make sure your sub sonic filter is set right otherwise the surround will start cracking.
box requirments is average to large depending on the power available.
out of all the 3hp varations i like that one the most. subsquent varations were tweaked for higher bl.
Well in my truck they will be on a bc2000d, they should be moving nicely :) so is there a replacement surround?
I've heard of a guy using the 10" hcca surround on one? Can I buy a whole top assembly like other Tc woofers?
