Patrick Danesky
What gague wire should i use?
Im running a 2500 watt @ 1 ohm amp into 2 SSA icon 12"s rated at 1250 watts rms each.
what gauge wire should i use to run from the amps single output into the woofer box, then to the speakers from inside the box?
10-12 gauge should be sufficient
^ What he said. I have some Knu 12 gauge that is easy to work with I highly recommend it.
Edited by Fearz
