Tarpon87
enclosure help 2 SA-8s
Ive had to scrap my original idea of using a single 8 due to the port length / space limitation for where I wanted it. Ive decided to use the pair i have and not worry about the space required. Im guessing eclosure volume would be double the single so 1.2-1.5 cuft, what should my port size and length be? this will be for every day use
thanks
After a little reading, i think slot port is the way ill be going
Edited by Tarpon87
Now we need some max external dimensions you are willing to sacrifice for an enclosure. This at a minimum would need to be greater than your required air space, plus the displacement of your slot port, and your subs. What vehicle is it going in will also help.
