CarlosRodriguez
just paid for a zcon!What rms are you pushing yours at?? HELP
Well as the title says just payed for 2 12 inch zcons dual ones
The Car : 94 bmw 325i
Electrical : xs power d3100, xp3000, mechman 320 alt. 2/0 welding cable in the rear soon to be 4 more runs of kicker hyper flex 2+, 2- for a total of 6 if neededninja.gif
Amps: pair of planet audio bb2400.1 strapped @ 1 ohm (.5 per amp)
Subs: soon to be 2 12inch ZCONS smile.png dual 1
the question 1 : will this be enough power to push them ??
q 2: what do you guys, girls run to your zcons ??
q3 : how long was your build time for them ?? if you remember that is smile.png
any info is appreciated
Edited by djrockstar
I ran a crescendo bc5500 to mine...so roughly 2600-2800 each
Expect 3-4 weeks before you get them...is a safe estimate
Question #1- depends on your enclosure size, enclosure type and tuning
Question #2- Most people i've seen on here run speaker wire to their zcons. Some others run DMMs to them when they screw them up and others run CA glue on them when they are rebuilding them.
Question #3- I can't answer this one.. just gotta sit back and watch Titanic a couple hundred times back to back and then.... They'll be there.
q1:its going to be a trunk box so about 2.5 at most per sub around 35 hz
q2: lol thats good info on that speaker wire thing laugh.png what i ment to say is rms power wise per sub
q3: have to get the rental card out and pick it up then pass out for around a month
how big of a box do you have them in ?
and figured something like that
I've run my Zcon 18 on 5k for sometime, but it takes some experience to run that much power without any problems. If you plan on running a ton of power make sure your box is on the small side.. I've learned this the hard way when upgrading power. Lower power = Big box, Lots of power = small box.
Current lead time is about 3 weeks excluding weekends.
2.5ft3 is not horrible, but you can get by with less..around 2 - 2.25f3 net each would be just fine and work amazingly well.
I'm running 1200 to mine in a 6cu box So I think you will be ok. But will be running 2500 soon. A few other members are running 5k (smartly) 3-4 weeks would be good estimate
Who are you talking too?
You quoted nobody!!!
gotcha trying to get a bit wider port then what i have probably going to build a in trunk box once i completely finish the electrical upgrades
i plan on up grading to around a single 5 k once i get rid of these amps and subs (sa-12s) still dont know exactly to what atm though
That only sounds better cus he said 3 weeks....excluding weekends.
My box was 8cf after displacement and tuned to 32hz...
Thank you for your order, I just finished processing it (them). Current lead time is 3-4 weeks unfortunately due to the "busy season" of car audio being right now.
When the subs are due to ship, you will receive a store email with your tracking information.
As I am positive any SSA subwoofer owner will tell you, they are well worth the wait.
Yes Mark I agree with you.
Ihave had 2600rms going to my 1 15 in 4 cubed tuned at 30hz. Loves the power.
And yes. Its well worth the wait for them
pictures of current stuff or this thread is worthless
my bad i got caught up with work wonder why i never got email resposes hmm but here are some pictures of whats in there atm..
what i use to set my gains..
the 320 amp alt
the sa -12s box tuned to around 35 hz
my two batterys
2/0 welding cable
thats All i gots for now should be more to come as i get it
on a side note should i fiber glass the spare tire well into the intrunk box or would it cause more issues then benefits??
that looks intense!!!
nice stuff man im digging everything keep those pics coming
I'm thinking this is going to be the next box any input suggestions?
Also this box will be fiber glassed inside, resin a matt
gross volume 7.18
port area 70 in^2
port area per ft 12.30 in^2
net volume 5.69 (2.845 per sub)
tune 37.62 hz
the zcon Have Arrived smile.pngadhd.gifpopcorn2.gif although i seen the Dam ups guy drop it off his truck from the top step in the front it rolled and my heart Dropped sad.png but i inspected it and its seem a ok angry2.gifjon.gif
didnt know to start a build log or maybe a mod can move thiss?? anyways onto the pics of the new STUFF lol
New New radio lol
and a 6 inch aero smile.png new box being built tomorrow
Looks awesome man! You are only using one 6" port?
I would've been soooooo pissed. Glad it's ok though.
