lithium
2004 Nissan Sentra 2way + sub
Finished this build over the summer for my brother.
This is an active 2way+ sub build for my brother's car. system sound great and my brother is very happy.
Equipment
alpine 9855
us acoustics usx 2080 (2)
kole qx1-3000d
fountek fr88ex
dayton rs 180
SSA Icon 12"
monoprice rca's
1/0 welding wire
cadence 8 awg
SDS deadening
pictures during the build are pretty bad. just uploading a few.
Random deadening pics
build pics
dayton rs 180
using these for midbass.
sentra doors limited my mounting depth quite a bit. perhaps he will let me cut up the doors and install some larger midbass speaker some day.
sexy sexy
simple single baffle, clay was added later
...forgot some pics of the mlv process :(
Fullrange
aiming
baffle
baffle on pillar
fg process
mix of fg and bondo applied, this stuff is awesome!
Flocking
so i picked a brown color that wasn't even close to right so i had to sand it off and re-flock with gray.. turned out great though!
Big Three!
battery gnd
chassis gnd
-no pics but its under the battery if your wondering
alt to battery
double run of 2 gauge (had some scrap sitting around so why not!)
Amp Rack / False Floor
-goal was to keep access to spare tire
Enclosure for ICON
i think it was 2.5 cubes @ 30hz
test fit
can still access subwoofer amp while box is in the trunk.
also, you just have to remove the box to get the space out.
First time wrapping a box. it came out ok, but i'd like to redo it someday.
Thats it, thanks for checking it out.
I'll get some nice final pics and post them up sometime
Good job on the build!
looks great. what crossover points are you using on the full range/woofer
Sweet build.
Pillars came out great. I really really like that grill on the icon, I need to find or make something similar for my door speakers.
Pretty cool you can still open the false floor with the enclosure in.
Looks clean! How do you like those mids?
I am also curious on how those mids perform.
Looks good for sure
don't know the exact points, something like woofers play 80-500 and the fullrangers play 500 and up.
you could run the fullrange a bit lower but the dayton can play well over 500hz so there was no need to force the fullrange lower. i just experimented until i found the best xover point.
i think they sound pretty great. awesome detail and retains enough top end to forgo the tweeter. i still prefer the install in my car but really they're different installs.
i did a little work tuning things but i need to sit down with my bro and dial things in for him. even with minimal tuning this is by far the best system he's had in his vehicle.
Sweet build.
thanks man.
if you have access to the tools i recommend you build the grill yourself. the problem with the grill i used is that it is too narrow, that's why its at a weird ass angle haha
