no_username
Amp wont turn on???
  On 2/26/2012 at 4:41 PM, nousername said:
hm im upload some videos though i doubt they will help
Just follow that wiring diagram to the T.But you could have other wiring wrong. Try just one sub but set the gain low.
  On 2/26/2012 at 5:02 PM, nousername said:
Wire one sub parallel 2ohm turn the gain down to start and see if its louder.
I dont have anything to compare to as my subs arnt even getting power
ok i will go wire 1 at 2 ohms brb
Edited by nousername
Then the problem is between the hu and the amp.
Yup no power at 2 ohms
could this be caused by a bad ground possibly? My amp light turns on showing it has power but i wanted to ask anyhow
Do you have a ipod?
Well i take that back. I had bass but there were just faintly playing
Let ne fiddle with my hu
Yes sir thats what ive been using. Via auxillery
Hook a ipod direct to your amp with the proper adapter.
turn your ipod up
  On 2/26/2012 at 6:52 PM, nousername said:
What adapter is that?
you can buy one at walmart. the plugin to 2 rca's to plug direct into the amp instead of your rca cables.
It is lol
I have a question... i had to buyban adapter to install my hu the gmrc01
Theres a wire on there called amp turn on. Now am i supossed to use that since my hu already comes with a remote wire
It is lol
  On 2/26/2012 at 6:59 PM, nousername said:
It is lol
As long as the amp turns on dont worry about them.
  On 2/26/2012 at 7:04 PM, nousername said:
Alrighty then
What about that adapter?
It will alow you to bypass the hu and hook direct to amp. best buy, walmart, target
  On 2/26/2012 at 7:19 PM, nousername said:
Pretty sure i got the right one. Just a 10$ adapter that has some rca and headphone jack inputs
Yep plug that into the amp instead of your hu rca's.
  On 2/26/2012 at 7:34 PM, nousername said:
Will do
Ok
  On 2/26/2012 at 7:39 PM, nousername said:
Did it work?
