Bradley Farmer
System Preparation
I'm currently a college student majoring in Electrical Engineering. A few years back, I competed in roughly about two MECA competitions as a hobby. The experience was great, but short lived. With my new schedule, I'm able to juggle classes and a job. With that said, I've decided to go back into competing so that I can have something "fun" to do outside of studying hard during the week.
I'm specifically looking to compete for SPL in MECA. What I buy from Fi will strictly be based off of the new point system for MECA. There are several classes, and I'd either like to compete in either Street 1 or Street 2. Street 3 is simply above my budget as a current college student.
The base formula for points is this in MECA SPL Comp: {(Total Amperage of In-line Fusing X 10) + Woofer Cone Surface Area} = Pressure Class #
Woofer Cone Surface Area (for formula above):
12" Surface Area = 113 Square Inches
15" Surface Area = 177 Square Inches
18" Surface Area = 254 Square Inches
Outlines for Street 1 and Street 2:
Street 1 (0 - 550) -- 1 Fuse Maximum. Amp limit: 1500 Watts Maximum RMS @ 14.4 volts
Street 2 (551 - 1000) -- 2 Fuses Maximum. Amp limit: 3000 Watts Maximum RMS @ 14.4 volts
Suggested Speaker?
The vehicle that I own is a 4runner. It is very similar, if not the same size as the interior of one of your stickies posted on this link here: http://www.soundsolu...7337-2-btl-18s/. My setup will consist of one driver, whether that be a 12", 15", or an 18". From going to previous competitions, I'm leaning a little bit more on the 18" side of things, mainly because a lot of people who compete own a lot smaller cars than I do, therefore they are able to get louder because of much smaller vehicle interior aerodynamics. With an 18, I can somewhat make-up for that lost ground. With that said, my question is this: what speaker should I go with, if I'm desiring to hit around the 147-148 dB range?
Suggested Amplifier?
Additionally, I'm also curious as to which amp you would recommend? So far, one amp that really sticks out to me is the MMATs M3000.1D. The amp fuse rating on those are rated at 100 Amps and the amp pushes 3000 Watts RMS at 1 Ohm. From doing math from the formula above, I will need to push around 70 Amps to still remain in Street 2 (assuming that I use an 18 inch driver). Is there any way to one, lower the Amp rating while sacraficing a little bit of power output, or two get a better amplifier to go with for SPL competition?
Wiring.
Wiring isn't really something that I have a question about. It's already understood that I will need to go with 1/0 gauge because I'd be pushing so much power
Batteries?
I'm thinking probably around 3 batteries for 3000 watts would be suitable. Is there a particular company that you would recommend and what particular specifications should I push for?
Alternator?
This will be the last step of the install. I'm thinking about something that produces around 200 Amps. Is there a particular company that you would recommend for both reliability and performance? I've spent a few hours looking around and there are so many different alternator companies out there, it was kind of hard to tell who's reliable and who isn't.
Conclusion.
This is a long post. A very long post. For anyone who takes the time to read this or to reply, I would like to say thank you. You took your own time out of your day to help me out and for this I'm extremely appreciative. I look forward to posting how things turned out with my Fi experience here in a few months. Thanks!
XS makes really good batts. Probably the best in the industry. Stinger red cased batts are great as well.
Great recommendation on the String Red Cased batteries. They seem like something that I could work with in means of performance and pricing. However, the XS batteries were a little over 1,000 dollars each (unless I was looking at the wrong thing) and out of my paycheck range. Thanks for the battery help armykyle1.
I have nothing to say but what a great first write up!!
I am too competeing in meca this year, actually first one is tomarrow in Lebanon TN.
A fellow member here by the name of Shizzzon and Ohjya have some experience in Meca and could better assist in this case, as I am too under their arms wub.png But from what I've learned so far is :finger: meca :lol:
Seriously, there are just wayyy to many restrictions to play both daily and comp, too much for me to not really care about classes once my new build is finished. Instead I will most likely simply compete in street 3/4 or mod 3/4. Also another option would to simply go for PNP.
I too have an SUV, explorer, and this is my only vehicle, so trying to balance both seems too much, especially comparing to people who are seasoned competator with competition only vehicles. I'm currently decided to venture off looking at other leagues simply because of Meca every changing rulebook, I would actually like to have fun with the system that I have instead of altering it due to chasing gold plated trophies. Just my .02
Look in here under xs power, SSA is an authorized dealer :) D3100 is 370 shipped I believe?
Great idea's glad to see people with a game plan, but you're missing one essential number for us to help. BUDGET! lol
I'm starting MECA this year too. Went to a bunch of Comps last year, but didnt compete. I'm running S1 with an AA Havoc 15, MB Quart 1500.1, and a 30amp fuse tongue.png
A fellow member here by the name of Shizzzon and Ohjya have some experience in Meca and could better assist in this case, as I am too under their arms wub.png But from what I've learned so far is finger.gif meca laugh.png
Yeah, I'm hearing that a lot about people not liking the new 2012 rulebook for MECA. If you're seriously wanting to change, IASCA might be the way to go. Although, I honestly don't know if they will be stricter or more lenient. I know for ""SQL"", IASCA requires the judge to sit in both the passenger's and driver's side to rate imaging and MECA does not. This takes a lot more time to image when you have a judge critique both sides.
Your first competition is tomorrow. Figure out, if you have not already, the aerodynamics of the car. In my first competition, I had two Mach 5 Audio 18's in a Crown Victoria LX running off of 200 Watts each.. My first run, I scored a 135.8 dB. On my second run, I simply opened up the passenger's door and scored 138.6 dB and ended up coming in first place in Amateur Street. Since you drive an Explorer, opening up the sunroof or window on the backhatch might help. I know doing this in the 4runner definitely helps me get a noticeable gain on the lower frequencies.
By the way, I'm from Huntsville. I might end up running into you sometime. I'll let you know whenever I get this setup and start competing.
Look in here under xs power, SSA is an authorized dealer smile.png D3100 is 370 shipped I believe?
Great recommendation. I'll have to look around a bit more, but as of this moment I really don't see anything negative about these batteries at all. It seems a lot more potent than what I had for my first competition (by far).
Well, I'm planning on taking a few months to install this. I'm probably looking around 3000 dollars to get this thing up and going. I ran the cheap route during my first few competitions and only managed to get 138.6 dB off of two 18s (granted I was running a total of 400W RMS). A little bit more time, and a little bit more money will help me get further than I was last time. But here's a few things I have outlined on pricing thus far:
Speaker - Fi 18" BTL N3: $850ish.
Amplifier - M3000.1D: $1000 dollars. Would like to cut this value in half, but I'm really not up-to-date on amps like I used to be. So much has changed in 3 years.
Battery - SX D32100: $370
Wiring - 1/0 Cables. $200. Might be this value, might be cheaper. My father's really good about finding wire on sale and he does ""SQL"".
Box - Self built. $100. Should be this or around $120. This is about how much it cost me for my last build and I had two 18's taking up the whole trunk of a Crown Victoria.
Alternator - I'll have to check to see how things go. If I need one, then I'll spend the money. Around $500.
Total without alternator: $2520. This is assuming I can't find an amp for around $500 that will get about the same performance as the M3000.1D.
A crescendo bc2000d good electrical wired to .5 ohms should be up in the 2500 rms range and it is 339$ shipped there are multiple amps under a 1000$ that put out 3000rms
Edited by Dangrebel
With that sound budget you have great chances.. and if all of your posts are as thorough as your first, I'd say you're ahead of the game.. The mistake alot of us make is to "think" we've thought our ideas well ... And bumps galore ... Good luck man.!! I like the parts picked so far..
Will you use this as a daily driver? If so I think the n2 would be a better choice
Sounds great on the price, but you're not quite as efficient at 0.5 ohms. P = I2R. Therefore, dipping your resistance value from a 1 ohm value to a 0.5 ohm value will mean that it takes more current to get louder, instead of using the larger resistor value.
Actually for that very reason, I've decided to go with two of the Rockford Fosgate Power T1500-1bdCP. The values of the 2 ohm and 1 ohm are pretty much the same. I'll probably end up running those amps at 2 ohm so it'll be more efficient.
Thanks man. Yeah, there's always going to be some curveballs and things that I won't expect. I just have to go with the flow and keep working at it. If it was easy, then everybody would be running the score that they want for their SPL runs. I was actually thinking today, and one thing that I failed to mention was soundproofing the 4runner. Not sure when it's going to get done but it does need to get done. The 4runner is no luxury car, and I'm pretty sure the factory soundproofing is poor.
Great post. I was actually reading today about the N3 and it basically said the curve response from 45-75 Hz was saddle shaped. A few other things that I read also said you wouldn't want to run the N3 everyday, because they heat up easily and they'll tear up quicker. I will most likely end up going with an N3 because of the frequency response curve and the fact that it is roughly about 2 decibels louder at the 1 watt margin than the N2. Turning off the subwoofer amps shouldn't be a problem. Listening to this everyday even at low volumes would be a sure way to go def quick.
Start reading at post #20. http://www.soundsolu...post__p__885520
The 2 rf 1500 bdcp's will probably be less efficient than the crescendo at .5 ohms, If I remember correctly the bc2000 is 86% efficient.
At four ohms, drop them to .5 and your going to lose that 86%.
  • http://www.audioque.com/AQ3500D1-Amplifier_p_32.html
  • under 1000
  • the difference between the n2 and n3 is marginal. Being as this is a daily car, I'd run the n2 and not have to recone it or worry about the heat any time you wanna just drive.
  • and lastly, on the alt, find a local alt repair shop and see if they can rebuild it bigger. my alt was 105amp, they took it (guy knew my dad so I got it done cheap) and it now runs 200amp. 105 at idle. paid 125 dollars I think and was out an alt for less than 24hrs.
Will they draw more power? Perhaps, but I'm sure the amplifiers themselves are more efficient, better designed, and more reliable then the crescendo, especially when wiring that low.
A lot of amplifier effiency ratings are done at a higher impedance load, and higher frequency tone.
I suggest getting a bunch of different size fuses (lower rating then wire rating & amplifier's onboard fusing), and seeing how long you can run the amplifier for, before each fuse size blows.
You may find that you can use a small fuse size to drop into a lower pressure class in meca, and the fuse will still pass enough current to do a short burp before it blows.
Might be helpful for competing. :)
thats what I'm doing. I can just burp with a 30a fuse on my 1.5k lol. but a couple seconds is all it takes.
