Is a kicker kx3 a good crossover to use? :ughdunno:
Good for what?
Good for what?
I mean using it as a crossover between tweeters and mids not active.
No.
What do you recommend?
No.
Something really expensive would probably do the trick, just to cover all bases.
Why don't you give us a little more information as to what exactly your trying to accomplish, and provide a budget.
No.
I have mids and tweetrs I want to install and adjust them .
No.
So your only using two types of speakers, 2-way.
Check out the rockford 360.2. It requires a laptop with bluetooth / pda bluetooth / etc for tuning though.
You may find it easiest to get a head unit that's capable of doing the processing. Others will have to talk about which models do what, that I do not know.
No.
So a equalizer wont work.
An equalizer allows you to attenuate and boost bands / sections of the frequency range.
A processor may be capable of multiple things: Time Alignment, EQ(equalizer), digital crossover system for speakers (crossover points and slopes), and some have their own "auto tune" algorithm.
You need to be able to apply filters to your speakers, so speaker A plays from x to y, and speaker B plays from y to z. BASIC description.
So isnt a processor what i need for my application
Yes, but the kicker kx3 is limited to what it can filter.
THen what do I use?
Tuned in. Curious about the same thing.
Audison Bit One
Audison Bit Ten
JBL MS8
Rockford 3sixty.2
Headunits, not sure exact specs on each, look for yourself.
Alpine 9813,9815,9833,9835
Pioneer Premier 860mp
eclipse 8053/8443
There are tons of choices, way way more then the above, you just have to look.
Audison Bit One
Audison Bit Ten
JBL MS8
Rockford 3sixty.2
eclipse 8053/8443
unemployed right now need a cheap option. By the way its doesnt mean I dont have money.
The most popular radios for running Active are the PRS units from Pioneer Premier.
800PRS
880PRS
P99RS
and the new 80PRS.
All can run active and have a minimum 16Band L/R separate adjustable EQ.
800PRS
880PRS
P99RS
and the new 80PRS.
All can run active and have a minimum 16Band EQ L/R sep adjustable.
Read last post
Audison Bit One
Audison Bit Ten
JBL MS8
Rockford 3sixty.2
eclipse 8053/8443
I asked you for a budget, you specified none.
800PRS
880PRS
P99RS
and the new 80PRS.
Read last post
Finding a headunit that can do it is the cheapest way you'll get it done.
800PRS
880PRS
P99RS
and the new 80PRS.
Read last post
ok thanks :drink40:
I have a premier head unit that has a bunch of time alignment eq and a ton more I have been tweaking it for years. I actually find it kinda useless. Once I enable the time alignment it turns to shit no matter what I do. Maybe something's not set up right?
The less T/A and EQing you need the better, but unless your setup is perfect, it should help. That is if you use it correctly.
