no_username
aq750
Does the aq750 have rca? My headunit is cde122 and has rca on the back
Not sure about all of this. Thanks
Yes as it has RCA inputs on it. You will have to buy the cord seperately
There not in a wiring kit?
While i have you hear. I had trouble crimping my ilkumination wires on hu. Is that only for when headlights are on deck lights dim? Or is that a dimmer? Idk
My hu only has illumination
Yes most wiring kits include rca's. I don't understand your other question?
He's asking about the 'Illumination" wire for his head unit. The lights of the HU should dim whenever you use your gauge dimming switch, if you have one.
Oooh ok. Idc bout that. I couldnt crinp that. Broke the metal they provide oh well
Thanks:) man cant wait to buy my setup ;-)
I think that you'll be happy :fing34:
750rms@1ohm 1%thd 1000rms@1ohm 5%thd booth @ 14.4volts :eek5wavey:
What sub are you using?
I will be using 2 (10") dcon dvc 4ohm
Good so you can wire down to one ohm. Each sub will get at least 375 watts rms.
That was what my data gathered
So wikk 375 to hit hard? Not two mile radius loud but enough to get a back massage?
I think they will surprise you how loud they get? Are you using a sealed or ported box?
With more then ratted power for the Dcon's, I usually suggest the standard size enclosure. With less then ratted, the optimal size is great.
i would say around 1ft3 should do just fine. Just make sure you have correct port area and tuning for the subs/application and you should be just fine.
Well i will be buying the box. I dont have the tools or skills to go custom box
D C Creations can build you one. :fing34:
Our prices on in the vendor section...
Here is a link...
We also offer a DIY Kit now.
Edited by pro-rabbit
How are they on pricing?
Also what size amp kit. 8gauge?
8 Should be enough unless you plan to upgrade later then I would do four. As for pricing you would have to get a qoute from them.
Bought my aq750 today!
Good for you.I hope you like it as much as I did. :eek5wavey:
Are you saying you dont like it anymore?
Only thing is it will give each dcon 375w. Im having to use a bigger box due to more power. Just gotta watch the gain so i dont fry it
