pro-rabbit
Pricing structure
Paypal
Any major credit card
other options can me discussed and generated per personal needs/requests.
Designs Pricing:
Sealed
Basic cut sheet design with no 3D model $8
Full 3D design and cut sheets $16
Ported
Basic cut sheet design with no 3D model $15
Full 3D design and cut sheets $20
Bandpass
Basic cut sheet design with no 3D model $20
Full design with 3D model $30
All designs come with tech support for your build.
If you purchase a design then decide you want the enclosure build by me, I will credit the amount of the design to the purchase of the enclosure.
Enclosure Pricing:
FT^3................SEALED........PORTED
1.0 cubes...........$90.............$130
1.5 cubes...........$100...........$140
2.0 cubes...........$110...........$150
2.5 cubes...........$120...........$160
3.0 cubes...........$130...........$170
3.5 cubes ..........$140...........$180
4.0 cubes...........$150...........$190
4.5 cubes...........$160...........$200
5.0 cubes...........$180...........$220
5.5 cubes...........$190...........$230
6.0 cubes...........$200...........$240
Anything larger is 100% custom quotes
Enclosure prices include:
Basic charcoal carpet
Terminal(s)
Proper Bracing (when/where needed)
Double baffle(when possible)
Rounded Port Edges (when possible)
45s
3/4" MDF Construction (Can be upgraded to Birch or any other wood you like)
In stock carpet options:
Color....................Under 5ft^3.............Over 5ft^3
RED..........................$10..........................$20
Blue.........................$10...........................$20
Brown/Tan................$10...........................$20
Black.......................$10............................$20
Gray/White Marble.....$15.............................$30
Blue/Black Marble......$15.............................$30
Red/Black Marble......$15.............................$30
In stock carpet options can be seen here. Almost any color and material can be special ordered to match.
If you would like a design or an enclosure please PM, email, or make a thread with the following info:
Which design/enclosure option you want:
Sub(s):
Music type:
Sub/port location(if you know already):
Amp(s):
Year/Make/Model of car:
Zip code:
Any any other information or custom options you would like to add..
Here is our current options for carpeting.
This is the "stock" option that is offered with all enclosures already.
These will cost extra but are options
RED
Blue
Brown/Tan
Black
Gray/White Marble
Blue/Black Marble
Red/Black Marble
off to a great start here. i have been thinking about a new box design this may be my route
shipping is extra, correct?
Yes. All prices DO NOT include shipping rates. Those will be provided on a person to person basis as each enclosure is different sizes, so rates will not be the same for everyone.
Edited by pro-rabbit
ok that makes sense
We had thought about a basic rate per enclosure. However, it would not be fair to those that are closer as they would over pay for shipping as the prices would be based off of the furthest zip from us. After some though, we felt that charging actual shipping rates is a better option and to help cut the over all costs that our customers see.
I should add a quick FYI on the pricing. This is for net ft^3 not gross.
So if you need an enclosure that is 2.5ft^3 with a slot port you pay for 2.5ft^3 not the actual 3.5(or more)ft^3 that is the actual gross volume.
Welcome over to SSA!! woot! PM'ing you for a quote on a box!
Edited by UsafBordeaux
Hey Pro.Ive been trying to PM you and even email you about the enclosures you designed me but you haven't responded.If you would,please get back to me.Thanks
I have not been in the office(I normally don't check my email away from the office), but when I get back to the house this evening I will go through our email.
Sorry for any delay, we have doubled our business since Thanksgiving and all though that is great, we are having to hire more employees to cover various things. Trying to train a receptionist to handle email is about the hardest thing I have had to do so far. LOL
Took a little bit to find what went wrong but we figured it out.
Some one else had read your last PM so I didn't get to see it. Now no one else will be check any of the forums we are a part of to keep that from happening again.
I will get you an idea on the actual size of what we were discussing on Monday.
Again, i do apologize for that delay.
Ok cool. Thanks.
Can you do 7 or 8 sided enclosures? Something like this,
I need about 1.75-2cu ~30hz for an AA Havoc in a hatchback. Preferably with sub up top, and room to mount two amps to it (thinking the 8 sided design would look nice sub on top, and amps on each slant), either 15in wide, or 24in wide. Depends on which section of the rear seat I put it behind. Have around 20-25in of length and height. If its something that can be done, PM me and I can take pics and measurements.
Edited by ctmaudi
We can build something along those lines. I have a few ideas that might work.
PM sent.
