Amish Marauder
sub diameter to cut hole for enclosure 15"
hey everyone. I just wanted to know what size hole was cut in your enclosure to house a 15" RL-p.
If I'm not mistaken on Sound Splinters web page it states that the diameter is 13.85 to the outsid edge of the surround.
So what I did was cut out a hole that measured 13.85 inches.
I put my sub in the box and it wouldn't fit. the whole was about 1/2 inch too small or more.
ten minutes later with my trusty jig saw the sub was in and clearing properly.
what measurement did you guys use to install a 15" RL-p??
they should update their web page with the correct mesurements. (or did I miss something?) :Doh:
Edited by Amish Marauder
the mounting cutout is 35.5cm so thats about 13.976 inches
That can't be correct. 13.976 inches? I cut mine to 13.85 I even used a micrometer. I then measured it when the sub would not fit and the measurement from one end of the suround to the other was a bit over 14"
now I'm really confused.
Umm, 13.976" is larger than 13.85", no wonder it didn't fit.
And the mounting diameter is listed on the website already....
http://www.soundsplinter.com/rlp15_premium...nformation.html
1" = 2.54cm
What kind of micrometer has the ability to even measure that large anyways?
Edited by ANeonRider
1" = 2.54cm
I know 13.976 is bigger than 13.85. on the sound splinter web page they have 13.85 listed. the whole I had to cut for the sub ended up being a bit larger than 14".
as for the micrometer I measured out 13" on my template and then used the micrometer to add the .85".
Also i didn't come here to argue. In my initial post I admitted maybe I over looked something and was just asking a question. I see where I went wrong now too. I was looking at the diagram in the upper left corner of that page you posted. I missed the info on the right hand side all together.
:huh2::huh2:
Measurements
Mounting Depth 21.5 cm
Total Height 22.6 cm
Outside Diameter 39.7 cm
Mounting Cutout 35.5 cm
Weight 39 lbs
Magnet Width 18.8 cm
Displcmt 0.21 cF
:huh2:  :huh2:
Measurements
Weight 39 lbs
Displcmt 0.21 cF
Read my post right above the one you posted and you will see that I found my mistake. I figure you didn't read my post and that is why you are confused. :P
Thanks for bringing this discrepancy to my attention.
I will edit the diagram over the weekend so that the same thing won't happen to someone else.
My apologies for the inconvenience :Doh:
:huh2:
No problem. It wasn't a huge deal, and was easily fixed.
:huh2:
:bananaDance:
