MatthewMoran
Questions about tunnels or manifolds
Does anyone have experience with sub tunnels(diamond,hexagon, octagon) or manifold style boxes?
I was wondering how they are for spl at low frequencies 25 to 30 hz(compared to a straight wall)?
You see it in a lot of Pro Audio stuff.
Check out the Bag End BASSAULT-R
www.bagend.com
It is fucking retarded, I installed a pair of them about 7 years ago.....
That thing looks crazy!!
They are generally bandpasses so they do well down low.
What's your goal?
My goal is spl at sub-30hz. The reason why I am wondering about these configurations is that my trunk is large but has a very small opening between the trunk and the back seat(and im not looking to wall yet). So the most I can fit flat with sub and port forward is 2 12's. But I have the cu ft for 3 to 4 12's.
What's your goal?
Well you want as loud as you can, break out the plasma cutter and the sawsall and start cutting that opening to make room for a large enclosure to slide into it.
What's your goal?
I can expand it by about 2-3 inches after that i would hit the strut towers, I can fit a large box in through the trunk opening. If I decide to make a box as described are there any problems I will run into sound wise?
I don't forsee any sound issues.
Me Neither, Should Be All Good If You Follow The Old Measure Twice Cut Once Rule.
I Swear To God I Saw Your Truck Yesterday In Bosier, Drew. But I Highly Doubt It.
