Eldorado
Pennzoil Syncromesh MTF
I found out that the tranny fluid resivior was empty on the accord yesterday.
Partly because i had no idea that it was for the tranny.
Has anyone ever used the syncromesh ?
Hopefully it will help the 3rd gear grind i have.
I use GM synchromesh in my Cobra. Pricey stuff at $12/qt. Not too well in the cold weather i.e. anything below 40. You shouldn't have a problem with that. Of course, you're not using the same stuff either. I think I'll be switching back to regular ATF this spring. I don't see any justified reasons not too. I don't have any grinding issues though.
I read you could use that as well. Im cheap so i'll use the pennzoil.
It never gets below 40 here.
It said use brake fluid so i poured some in.
I really thought it was for the ABS.
It only grinds in 3rd gear when engaging, its not that bad but you can notice it a little bit.
Is it a worn 3rd gear synchro? If so, the fluid won't really help that much. Is it possible that your clutch is about to go? It could be a partially worn synchro with a nearly bad clutch makes third gear unhappy...
Is might be.
Every other gear engages just fine and the clutch works fine.
I think hondas have a bad 3rd gear synchro
