Right so im gonna be running an mb quart q150 4 chan amp and a sundown 3500.
what i want to do is run the 4 chan off of the stock alt/electrical with big 3 and a yellow top.
a friend of mine has a 190 amp alt that he wants to sell me and hes also machinist so he can make brackets and whatever i would need to do this so mounting shouldnt be a problem.
i want to have the 2nd alt isolated from the cars electrical and simply dedicated to a bank of batteries (couple kinetic hc2400's or there abouts)
he said the alt is internally regulated to 14.8 v.
so i guess the question is.. is there anything wrong with running the 2nd alt like this? any hickups or potentially dangerous problems i might face? =X
thanks!
nothing wrong... but personally i'd just run it all together...
so run the alts parallel? there wont be a problem with the voltage difference between the two?
If the two alts put out the same charging voltages, I would wire them together ...
If they put out two different charging voltages, then you have to run them separate ...
but If i did this, i would run all stereo amps off the secondary alternator ...
just my suggestion here ... :drink40:
theyre similar. and i would guess close enough. the HO alt is 14.8 and stock alt is 14.5 but thats with the vehicle at idle so i imagine the load the car draws probably drops its those few tenths.
the main reason why i wanted to run the 4 chan amp off of the stock alt is so the sundown mono has the HO alt all to it self :P if it was like a 300 amp alt then for sure i would run the whole stereo off of it, isolated from the cars electrical.
btw thanks for the replies guys!
