edouble101
Why is my carpet wet?
It wasn't as bad as I thought it was going to be, mine's sitting in my room LOL.
Well I went from doing an elaborate custom build to doing a simple 1000w build. Deadening the roof just isn't in my plans.
90% of the time it is 1 of a few different seals on the firewall. The a/c box will Only leak over to the drivers side during Hard cornering. And when that happens it will usually run over on your feet if you don't have shoes on. The other Major seal that likes to leak over time goes around the steering column. But the Best choice I have found Many Many times over the years are where someone has drilled & or shoved that power wire through to the passenger compartment. I Always take a caulk gun & use some Fast 5 min setup clear silicon & silicon the Shit out of where ever I rammed wire through.
