zooyorkajd
need help with a box build
a. Subwoofers in question, number of subwoofers & subwoofer size: Dual SA-10's
b. Amplifier being used, specifically the model number: 1200 watt Hifonics Brutus (will probably end up upgrading it to a 2000)
c. Fabrication skill level: will be made by a box builder
d. Preferred material to be used (i.e. MDF, fibreglass, etc): mdf
e. Vehicle which the subwoofers will be used in: 93 toyota celica
f. Musical preferences: rap
g. System goals: SPL all the way
h. 37 Hz range
2-2.5 cubic feet would be great for those subs on that power. Are you looking for a design that you can print out and take to your box builder or are you looking for a builder online? What does your electrical system consist of?
This post is much better by the way. :fing34:
yea, i would was gonna print it out and take it to a builder, its 4 gauge. there running at 1 Ohm
You can contact Bromo or RAM_Designs here on SSA for a design.
