matj1990
Need help with box for a couple sa-12's
max dimensions are 17"h x 31"w x 27"d
i will be running a crescendo bc2000
thinking pretty much the same thing anton miller has setup in his cavi it seems to be really efficient
i want to be able to hit the low's really well so im thinking 30hz tuning ?
this is what i have come up with so far
27w x 16h x 25d using 3/4 mdf should get me 5 cubes
after sub displacement of .14 i should be at 4.72 using a 6" aero tuned to 30hz i need 14.5 inch flared and with port displacement i should be at around 4.5 cubes witch is max recommended for the sa-12's
if im doing something wrong please let me no i plan on building tomorrow
And yes i amp a complete noob when it comes to building a sub box :puzzled:
First of all: in my opinion that is not enough port area. Would you consider building a slot port?
rather stick with aeros so i can always re-tune easy
why do u think not enough port area ? worried about port noise ?
i can send you a design for free just send me your email in a pm and no thats not enough port area
thought i would post a link of the box im thinking of making i believe he is using only a 6" aero ?
i did a while ago said on Facebook said it was 6" and 5 cubes i think
btw i did pm you
and what do you think i should use
let me work on the design and ill let you know what will work
sounds good man anton said that where his port is placed gave him the highest spl btw apparently he does allot of testing idk im a noob lol so just throwing it out there
What is the xmax of the SA-12?
Believe they publish 19mm one way
Alright I just found that. So we have 19mm xmax, two 12" woofers and tuning @ 30hz? I come up with 8.92 MINIMUM diameter if using round ports. If using slot port then 62.45 inches.
i believe you are correct
so am i looking at 3- 3" aeros ? idk lol remember im shopping at home depot :P so what should i be using
I would go with three 4" aeros. I buy mine from parts express. They are the psp brand. The problem you need with three 4" is they each have to be 22" long. Could you raise tuning to 33hz? This would mean you wouldn't have to cut them down, since they come in 17" kits.
length is not a huge deal i am making them out of pvc
Edited by smokey
Well if you are making them yourself. Three 4" Pvc ports. Each 22" long.
in a 3.5cube box should do good
where do you get 3.5 cube ? im looking at 4.5
also does port displacement effect tuning ? do you calculate port size before or after port displacement
and what is 3 4" 22" long aeros going to displace ?
Edited by smokey
It will displace .48 cubic feet
so i would be looking at roughly 4.24 cubes
Port size does effect tuning. So when figuring out box size you need to take size + port and sub displacement. Just adjust the total size and make it a little bigger. If you can't go bigger adjust the size to 4.25 and refigure port length and displacement will change.
I have had great luck with two 12" SA-12s tuned to 32hz and 4.0cubic feet.
so what am i looking at with my current configuration ?? would be like 31-32hz right? becuase now im lost lol
what do i need to size wise to get my 4.5 cubes and 30hz ?
my max dimensions are in first post btw
Edited by smokey
On my phone right now. I can recalculate here in a bit. If those are your max dimensions, stick with the numbers above. Tuning may change 1 to 2 hz but it won't be noticeable.
