What type of amp should i get to run two skar audio vvx 12" dual 2ohm vc.
I'm thinking two Hifonics hf 2000d's one on each sub.
My limit it $500 for a good quality amp that does either 3000+ watts at 1ohm or .5ohm.
I want .5ohms stable
Edited by backyardbass97
Why do you need that much power for a pair of subwoofers that are rated at 600wrms each?
^^What he asked!!! And why .5 ohm stable?? :ughdunno:
Something like this would be fine. Also would not be hard on stock electrical.
because there not the most efficient subs and there going in a small spl box so they perform better with more power
i just went thought this for my sa-12's
i wanted 1,000 to each sub though figured it would be more then enough !!
through alot of reading my end choices were
cheap- ap15001d or ap18001d
crescendo bc2000d
and db-r.com's saz-1500d
well this is for an spl set up so if i blow them then ill do a recone so why dont yall give me some suggestions on some amps
Here you go!!
Are you competing? If not I don't see any reason to run so much power to those subs....especially at .5ohms. If this is for daily you should reconsider.
well its my brother system and he wants an spl ground pounder and yea were planing on competing
