99 accord coupe 3.0L...pretty sure the alt puts out around only 100amp...i need to figure out if i will be able to power around 1300RMS for my fi BL..what all should i get? I got the amp, used to have 4 gauge thinking about running 0 gauge with the new set up..i need suggestions i really have no idea about this kind of stuff, extra batteries new alt??anything guys need help.. thanks!
What amp are you using? Typically you won't need an HO alternator to push that ammount of power. You might be able to get away with a bigger starter battery or an extra battery in the trunk. I wouldn't be too concerned what you stock alternator puts out because you don't know how much of that amperage the vehicle uses. The best thing to do is install the equipment and monitor your voltage. Upgrade your electrical as necessary. No matter what be sure to do the Big 3. If you don't know what that is there's a sticky here on what it is and how to do it.
Edited by theluker69
Yes im somewhat familar with it. Thank you for the feedback!
Info on the BIG 3
