Hotdog69
My Wife's Grocery getter build log
Well my wife decided she wanted some beat in her ride so I just got done with everything and figured I would create a build log for everyone to check out. The goal for this build was to keep the vehicle functional as if it were stock and still be able to use the cargo area to haul stuff.
2008 Chevy Equinox
Some images of it Stock
Stock Radio
Back of vehicle Stock
Audio gear and Parts being used
LAN Data Bus Interface GM Onstar GMOS-LAN-01
F3 Street 0 Gauge amp package
Bullz Audio 1/0 wire
Antenna adapter
Assorted Mini Anl Fuses with led's
Ground Distribution Block
Power Distribution Block with Voltage guage
Rockford Fosgate RFX9300
Rockford Fosgate P500-2
Rockford Fosgate 400.4
not actual amp I am using but Picture for refrence.. I am using same style but with gray caps
Two Rockford Fosgate P2D412 subwoofers
More in next post...
The box was designed to be inverted so that my wife can still use the cargo area to haul stuff with out damaging any of the equipment. I wanted to use the entire cargo area but keep the box slim. I used Bass Box Pro 6 to design the box.
Box Details
Now first thing I did was to get my power and ground wires ran from the battery back.
I had to move all the stuff out of the way to get access to the battery.
I used a distribution block for the Power wire and used the factory connector for the ground.
For your comparison.. The (Bullz Audio wire is the black wire) (f3 Street 0 gauge is the blue wire) (Knukoncepts 1/0 is the red wire)
I got the Blue and Black wire through the factory grommet took a little lube though :).
Here is a few picture of the Rockford Fosgate Radio Installed.
I really thought that it looked good in the dash and I am happy with the integration kit that I used to mount the radio.
Got the Rockford Fosgate 8 disc cd changer mounted under the passenger side front seat.
Back view of the box with the back hatch open.
Couple views of the Box from the inside with the hatch closed.
Now the amps and fusing mounted onto the box view with seats down.
Still need to put the chrome covers back on
And a few views of the subs from under the box.. I used 2x2's around the edges to get enough gap so the subs are not pounding on the floor.
I will try and get some video of it all in operation soon.. but my initial thought was that It could probably do a 139-140 on the meter. I was really impressed on how the box sounded in the Equinox, it was a lot more then I was anticipating.
The first run was a 140.0db with the vehicle sealed up and mic on the dash.
After my first run the rain poured down for about 25-30 minutes then it got real hot and humid that's why the scores went down from there I suspect.
Not to bad for two 12's on 500 watt amp, I was using a 40amp fuse to drop me into S1 class still took third place Winner was a 141.5 and second was a 141.4
It turned out great!
:morepower1: to the grocery getter installs!!!
My wife loves it, I dont have any pictures yet but I recently put in a couple old school Power RFR2212 12" sub's and put it on a T1000bd amp. Lot more punch now should be in the 143 range or better.
Nice build. Love the older RF stuff. In for pics of new setup, and vids.
Thank You
Dont know when I will get it metered again since it is a grocery getter. I might take it to a local unsanctioned event but for the sanctioned events I will take my Mountaineer.
wish my other half would let me install some of the old stuff i have laying around. she thinks her stock system is more than enough but loves cranking my radio up when my sub hits.
nice little install you have going. sure, the box takes up a lot of space but great idea on the down firing to allow said groceries to sit on top. hopefully they don't spill with the beautiful box bumping away
Thats how my wife and I met 21years ago because of my car audio so she has always loved it too. Ill have to remind her not to set the eggs on top :)
Back then I had two Rockford punch 150HD's on two Power 12's and a Rockford Power 300 on 2 set of tweets, A midbass and two midrange in each door and 4x10 in the rear deck of my 78 olds cutlass with leopard skin interior.
Have tried a few times to get the wife to let me give her a little bump, but she ain't going for it. Never been interested.
Looks great, sure your wife loves it!! :fing34:
The best part about or I use to always take my vehicle when we went somewhere. Now have a system in her vehicle it does not matter what we take because I am going to have some beat.
