Angelboy863
Picking a battery for my system
Complete System:
1 15" Sundown Audio Nightshade Dual 1 ohm. .wired at 1 ohm.
1 Sundown Audio SAZ-1500
Box specs: cant release havent built.
Kenwood headunit, stock speakers for now.
Big 3 upgrade with Kicker 1/0
Kicker 1/0 wiring on everything(amp, battery)
Stock alternator (130amps)
Now picking a battery..
what would be the best budget minded battery for this system?
Now, im looking at a XS Power D3100, but is that too much?
Is a XS Power D5100 good enough? the D5100 has max amps: 1,600A and the D3100 has max amps: 3,200A
My system only has 1500rms so is the D5100 good because its max amps are 1,600A?
I really dont know anything about batteries so dont go picking on me because of my knowledge. Id just like some answers from you guys because you guys know more than me. thanks.
If its for under the hood, pick what fits in your car. What is the stock size? If its for the back I would use the d3100. By the way a dual 1 ohm sub can not be wired to one ohm.
I just realized that. So I guess I'll go even less than one ohm. But it would be under my hood. And I'm asking because I'm trying to see if I even need a second battery. If I got the d3100 that's all that I need right?
You will just have to see. Every vehicle is different. What kind of vehicle?
I have a (2)D3400's in my Hyundai. If I can fit a D3400 under my hood it should fit in just about anything :ehh:
02 ford ranger. It's going to be mine in about 2 weeks, same time my equipment will come in.
Sundown amps are not covered under warranty when ran below 1 ohm FYI
See what size battery comes in it and get a XS Power AGM battery to replace it. Then go from there.
I bought my amp from a friend
So which battery to pick? My battery and box are the only things I need to get left. Well besides my car lol but my parents n I are doing paperwork and it should officially be mine in about two weeks (well my dads but my car technically.) d3100?
Get the largest you can fit under the hood. Watch your voltage and go from there. If you're getting bad drop get another, depending on the space and money available, battery in the back. :morepower1:
