BanginGMC
SAZ-3500D
I'm aware that each SAZ-3500 might have a slight difference in power but..
Generally, what would the output be at 1ohm while at 13.5v?
I'm also interested in knowing the same information with the current SAZ-4500D.
If your referring to the same thread as on here, the 3500 isn't one of the amplifiers being tested.
why not clamp yours to see what it does in your install
The test thread I posted is probably as close of an answer as you'll get -- once wired to a sub-woofer power will vary dramatically based on frequency and enclosure.
I'm going too, I wanted to know this information so I can compare it to what I'm doing, thats why I started this thread.
Okay I'll go check that thread out real quick.
