keddy_net
  On 6/4/2011 at 4:02 PM, dogman said:
  On 6/4/2011 at 10:46 AM, keddy said:
i want to buy dual 2 ohm subwoofer and use it at 1 ohm.
I would run the sub at 2ohms not as hard on the amp or speaker unless setup properly.If you do go 1ohm I wouldnt run over the 1750rms power rating of the sub.
so you recomended me to use that subw at 2 ohms? In this case i have to buy xcon dual 1ohm?
This sub doesn't run properly at 1ohm at 1750w ?
