ricksi30
4 10's Sundown Audio
So I decided to pick up another Sa10 so I can wire down to one ohm. Now I just need to figure out how to fit these in my Infiniti I30. I've always done sub back, port back but can't with the four tens. I'm thinking about doing port and subs up, I've also thought about subs up port through the armrest. I'm capable of designing and building the box, just wanted to know if anyone had any advice about the layout.
Thanks -Rick
Vehicle dimensions would help.
You may be able to angle the baffle using two panels so it would form a V
Depending on width and angle you'd have to use...
