i have a 2010 Nissan Frontier with a 110a alt. right now i have an saz-1000d and 180w 4 channel amp on stock electrical with very minimal headlight dimming at full tilt. will the big three and a kinetik hc2000 near my amp be enough for me to run a crescendo bc2000 and my 4 channel?
Well, noone can say for sure but you should be alright with those minor upgrades. The only way to know for sure is to install it and see.
double power ? You should test ! But I think it can be fine with big3 and another battery.
It may be better to upgrade the front battery before. I did not do it like that because of the price of a battery . I did not want to change a battery in good shape. I added a Kinetic batt in the rear, and I will change the front one later !
Be careful : I'm not an expert, it's just my personal experience.
Just have to install and see. I would recommend changing the front battery as well, and putting the largest battery you can afford in the back. Can't have too much electrical.
p=e*i
e=p/i
i=p/e
e=12
p=2000
i=166 approx amps
110-166=56+lights+ect ect
so maybe 70amps needed
so lets say ur batt is 120ah
u know have a reserve of
120-70=50a
a 120ah batt can supply(120*12)= 1440watts
a 110a alt can supply (110*12)=1320watts
1440+1320=2760watts
at 14v u need even less so on paper you should be fine :peepwall:
thanks. i know the only way to know for sure is to install just wanted to get a feel if it might be too much.
You should be ok. Make sure to not skimp on the power/ground wire. Use 1/0 gauge or greater.
