tysonm
Best place to buy wiring kits
I just bought a pioneer avh-3200bt, pioneer gm-d9500f, and pioneer ts-d1720c speakers which came with 2 subs, 2 tweeters, and 2 crossovers. Where is the best place to buy an amp kit for it and how do you hook up the speaker amp wires when you have a mono amp hooked up to a subwoofer?
I know how to hook up the subwoofer and amp without any problems, but I've never hooked up component speakers before and am a little confused on how to hook up the speaker amp to the back of the HU and to the battery if I already have a subwoofer amp connected to both?
First go get some knukonceptz wire and build your own kit. Second does your h/u only have 1 rca output? It should have a set for front rean and sub. Thats what you will need for the componets amp.
This is the PDF manual for your amp and I think it was page 7-10 that cover info on connecting to HU with RCAs. Also goes into connecting your speakers as you asked about before.
If you already have an amp, what size power wire do you have running to it, you may could just use a distro. block to split the power to the 2 amps.
If an amp wire kit is needed and you want a kit, here is a seller I have used before that has quick shipping and fair prices: http://darvex.com/store/pc/Amplifier-Wiring-Kits-c2.htm
I think I am going to buy this kit for my subwoofer, is there a kit that is close to the same price that comes with RCA's, since this one does not? http://cgi.ebay.com/KnuKonceptz-KCA-1-0-Gauge-Power-Amp-Install-Kit-w-Fuse-/380330435696?pt=LH_DefaultDomain_0&hash=item588d75e470#ht_1816wt_1139
Or should I buy this kit and then buy the RCA's separate?
and how does this kit look for my wiring for the speakers? http://cgi.ebay.com/KnuKonceptz-KLM-4-Gauge-Amp-Kit-JL-Audio-500-1-/380325513006?pt=LH_DefaultDomain_0&hash=item588d2ac72e#ht_4137wt_1139
I ordered a 1/0 gauge wiring kit for my sub and a 8gauge for my speakers, and now I just need to know what type of wire to get to run from my amp to my speakers, I can get 16gauge pretty cheap, but I don't know if 16gauge will allow my speakers to get there maximum potential in power or not?
Will this allow my speakers to get there full power, or will I need a bigger gauge? http://cgi.ebay.com/100FT-High-Quality-16-Gauge-Ga-Awg-Speaker-Cable-Wire-/170627691191?pt=LH_DefaultDomain_0&hash=item27ba33f2b7#ht_1371wt_905
