Lschevy
Sub and port placement
Which option is best?
1 member has voted
  1. 1. Which way
    • Option 1
      1
    • Option 2
      0
Im starting my build in about a week or so and i narrowed my design down to two options. The first option is to have the sub up firing at the rear deck with a kerfed port(s) firing back or sub up firing at the trunk lid with a kerfed port(s) firing into the cabin. after doing a lot of searching i see a lot that like the sub up port back. The reason i chose these two designs is because i cant do both sub and port back or sub back and port to the side. Which option would yield better results? I also its vehicle dependent but my box will have to be build inside the trunk so moving it around is pretty much out the question
Most trunk installs I've seen with good scores are sub and port firing both front or both back.
If you do build it inside the trunk, just seal off everything and fire both sub and port to the front.
i cant because the seats dont fold down
Cut that sum-bitch out!
"better results"?
I wasn't joking about the rear seat :)
subs back port side worked well in my chicks grand am.....
in town cars i found that sub back and port back sound better... sub up port up ahh deeper but not better
