rta60460
box for 2 Fi Q 12's
will a 4 cu ft box all one chamber tuned at 32hz be ok for 2 12 Fi Q? or do the chambers need to be seperate for each speaker? thanks
Edited by rta60460
First of all, there's nothing wrong with a common chamber. However, is that 4cuft with or without the sub and port displacements figured? If it's without, you'll have less than 4cuft once the sub and port displacements are accounted for and you'll most likely be right at the bottom end of what's recommended for them.
ok so iif i just do a 5 cu. ft. common chamber they should sound good?
