Brett_the_Vandal
Build help!!
Okay. So I've got very limited trunk space. And a small-ish. Budget. I'm hoping for someone to help me with some sort of box design for an FI Q 10, in a ported box. Max dimensions being 30" Wide, 14" High, and 17" Deep. Already have an Amp picked out too that i'm gonna buy from a buddy for good.
Go to the tech section and check out the ported designs for an icon 10. As far as I know, the Icon and Q are fairly comparable and a design for an Icon 10 should work with the Q.
The XMas on the FI is 8mm bigger than the icon. Problem? And most all of the other stats are remarkably different. like off by 5~9 each. Couple of them are close if not the same.
