Infinite913
RamRod new build 2 18's *IAK*
:woot: Get to work!!!!
i'll start ur box in a couple days hopefully.
Gotta get his specs so he can build this thing.. yet again, lol.
Now, Stu.. a word of warning....
If i do a design for you and come to find out you measured incorrectly like Dave did.. oh man....
I'm bringin the Posse and haulin ass up there and we all goin to Applebees for 13hrs straight and nobody's leavin until Hove finishes all 25 plates of food i'm gonna make him order...
then i'm gonna shove a tape measure up someone's ass and tip the waitress whatever number comes out first.
Besides that, i feel pretty confident in your design Stu. :WTFBubble:
Oh.. and Casey, if u see this... you're next after Stu.
Ok man, box specs-
Remember before i begin- the FLOOR ( between wheel wells) and TOP are SINGLE layer. EVERYTHING else BUT the inner port walls are double layered.
Now let's begin-
Floor-
38" wide
28" deep
Back wall-(sits on top of floor)(double layered)
This is the piece that looks like a thick "T"
Bottom part of back wall-
38" wide
6.5" tall
After 6.5" tall, proceed with the following-
48" wide
23" tall
Total height of back wall- 29.5" tall
Lower Side walls- (double layered)
These fit in FRONT of the back wall on the lower portion of the back wall.
6.5" tall
26.5" deep
It is the same on both sides
Now, the floor that will overlap the wheel wells.(double layered)
Remember, it will sit a little bit over the wheel wells so it's advisable to fill between this and the wheel wells to brace after building this box.
This flooring is for the ports and dimensions are same on both sides.
This flooring is also mounted on top of the Lower side walls explained above.
6.5" wide
26.5" deep
(make sure u let these completely dry before attaching anymore pieces to this piece because it is only being held by the lower side wall and the back wall...)
The UPPER side walls- (double layered)
Same on both sides-
These will amount on top of the floor you just made above(and after it has fully cured! very important)
21.5" tall
26.5" deep
Next is the inner port wall-
This is single layered and has same specs on both sides.
22.25" deep
21.5" tall
This gets mounted on the floor that is mounted on top of the lower side wall.
So, you will mount this on the edge of the floor, leaving EXACTLY 4.25" width between this wall and the UPPER side wall on both sides of the box.
ALSO, when mounted properly, there should also be EXACTLY 4.25" of space between the back of this port wall and the BACK wall of the box.
Now, onto the baffle-(double layered)
This mounts in between the lower side walls, the floor above those and in between the inner port walls.
35" wide
29.5" tall
Subwoofer CENTERING positions.
The following is to ensure that your sub cutouts will fit onto this baffle staggered.
The following specs are based on an X/Y axis.
X= horizontal
Y= vertical
Measurements are made measured FROM the LOWER LEFT corner of the baffle.
So, if i say-
x=6, y=12
that means, from lower left corner, go 6" to the right, and 12" up.
Now, here are specs-
speaker 1 mounted on top left of baffle-
X= 9 5/8"
Y= 19 3/4"
speaker 2 mounted on lower right of baffle-
X= 25 9/16"
Y= 9 1/2"
PLEASE NOTE-
Please make sure i am using the proper information for making these cutouts PRIOR to assuming i'm right.
Cutouts are based on following assumption-
Cutout hole- 16.75" diameter
Outer diameter- 18.5"
If that's right, then my numbers are safe.
Also, please use a compass or take your router bit and graze it across the mdf to scratch a circle around the baffle to MAKE sure that you have your center point exactly where it needs to be and there will be no mounting or sub placement problems!
I'll let you know about the internal bracing when u get there..
Do NOT put baffle on before installing most of the internal bracing though!
When u are ready for the baffle, let me know!
Also, the top is-
48" wide
28" deep
SOLD THE JIMMY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
LMAO,
dang bro, I thought I changed shit a lot, you dun changed the truck too. HAHA
did it get sold??? kid take it without any problems?
LMAO,
:morepower1: bigger truck = bigger box! BOTTOM LINE and Ya top he helped me fix it then bought it! and bought my wires with it!
Shizz is gonna slap the shit outta you! LOL!!
:banhim: :banhim: :bsflag: :bsflag: :fing23: :fing23: :fing23::faintthud: :faintthud: :dammit: :dammit: :dammit::Doh: :Doh: :threadsucks::deadhorse: :deadhorse:
:nothingtoadd:
5 pages and then disappointment :ughdunno:
