deepsilencer
deepsilencer's 2008 malibu ltz
A few of you guys wanted me to post up pics and vids,of how i started everything,
well here we go.
starting up when the malibu was a virgin lol
2008 malibu ltz 3.6 litters 4 door sedan w/out sunroof feature
2 tone basketball/charcoal interior,
160 stock alternator
premium 6 cd changer upgrade
i started my way out right away and started upgrading my stock audio and entertainment system
my stock visors
aftermarket 14.5 TFT visors
my stock stereo
my old accelevision to play the visors and headrest screens
upgraded it to a alpine iva-w203
bye bye stock stereo and accelevision
audio system
my stock speakers,idk where my other 6.5 went lol sorry
my orions (mounted under the seat)
my rockford 6.5mids and highs
2nd system(my current system of today,different box)
2 ascendant mayhem 12s
3.5c. ft @35hz,design from brian owens,texas ascendant audio dealer,box built by 991s10walled
pwk desing box(long horn)designed by pete,built by 99s10walled
3.45c. ft @20-80hz-mine peaks at 50hz-
AMPLIFIER:
AQ3,5000D1 (4,3000RMS)
External Fuse Rating 380 Amp in-line, 760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @ < 1% THD 4300W x 1
1 ohm Power @ 16V @ 1% THD 5300W x 1
1 ohm Power @ 18V @ 1% THD 6000W x 1
1 ohm Power @ 18V @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V @ 10% THD 15000W x 1
Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H)
Power and Ground Inputs 0 Guage x 2
POWER/ALTERNATOR:
my old 270 mechman alternator
It did 165 amps by 700 rpm engine speed, full output by 1800 rpm engine speed.
THE CASING'S MOUNTING HOLES DIDN'T FIT =/
stock 160 alternator's measurements
270 mechman alt
matthew logan from mechman was nice enough to modify one of my extra stock alternator that i had
for the malibu,so it can be a direct fit for sure
my new one
it does over 300 amps by 1800 rpm, with over 170 amps at 700 rpm engine speed.
they tested it in the dyno and it did 319 amps at 1800 rpm engine speed
The most unique part about it, is the fan cooled, external rectifier.This takes all the heat produced by the rectifier, and mounts it remotely, away from the windings of the alternator.This way, the air is not pre-heated before it gets to the windings, so the windings stay cooler, cool down faster.Also, because the rectifier has constant air flow across it at all engine speeds, (courtesy of an electric fan inside the rectifier) it is almost impossible to overheat it.(overheating is a common problem on 300+ amp alternators)
The bus bar on the rectifier makes it easy to hook up huge positive and negative cable runs to the battery(s)
KINETIK HC2000s(UPGRADING)
RIGHT
LEFT
GOODIES:
for the meca show this sept. 11 2010
audio control epicenter
gotta have it for them corridos lmao
stereo harness
video amplifier
3rd new box for you guys to hear ha :drinks:
this one is tuned to 34hz
see what good i can get out of it
box designed by james(audio innovations)
box built by 99s10walled
did some vids when it was being build
and also tooked some pics
(pics are inside 991s10walled's iphone
so as soon i get a hold of the pics i would post them up asap)
and also i would post up the vid tomorrow,i want to add some sub and flex action at the end of the vid,
hopefully youtube wont get this one deleted ha
some pics of the recent system =)
i sealed off the trunk
[bIG THANKS TO MY BUD KEEPINITLOUD FOR HELPING ME OUT FINISHING THIS PROJECT =)]
(in pic 2 aa mayhem 12s)
box tuned to 34hz
upgraded to two xs power d3100s(in pic aq 3,500.d1,AC epicenter for the spanish lol)
did double 0 gauge runs to my amp,fuses,big 3 and new mechman decal =)
(in pic decal 4m techforce,mechman 320amp alt and external rectifier)
i added sound deadening and put the malibu in the t.l
this was last year
did more tweaking,got louder
thanks keepinitloud and randy for letting me use your audio shop =)
finally took out beefy out of the box,i thought it was time =@
and installed to its place,no more stock :werd_msword:
SNEAK PREVIEW/NEW UPDATE
I ADOPTED ANOTHER KID FOR THE MALIBU :drinks:
THIS IS THE AQ3500D.1
IT'S ALREADY STRAPPED TO MY OTHER 3500
I HAVENT REALLY MUCH DONE A LOT OF TESTING CUS I WAS REALLY BUSY FINISHING
THE SILVERADO'S BOX YESTERDAY,BUT IT'S HOLDING ON PRETTY WELL
Edited by deepsilencer
Real clean looks... Love the white!
you gotta do a video with some corridos alterados... lol
you know what, I want some reggaeton happening on that system... When I get my ported enclosure I will be doing some vids of reggaeton since no one seems to have that going on... lol
