ssh
Vehicle - Equipment - dB results
Firstly, don't tell me just because someone in their honda civic can hit 150db, that I can too in mine. I understand the differences between installation and burping vs music.
I just want to see what people have been able to pull off in their vehicles.
Also state if vehicle was walled.
I'll start:
Vehicle: 1997 Jeep Wrangler (2door, hardtop).
Equipment: DC 270xp alt, saz1500d, Fi BL 18" (33hz tuned enclosure).
Meter placement: headrest
Music: not metered, guessing ~140-142
Tones: 40hz, 143db
I'm about to get a new vehicle and would like something sporty to drive, so space will be a restraint, but I'm curious to see what others have been able to do in their vehicles.
Vehicle: 2000 Volvo S40
Equipment: Optima D34/Batcap 400, RF Punch 500-2, IA Lethal Injection 12" in 2.5 cubes @ 32 hz
Meter placement: Sealed on the dash
Music: Bass Ballin' - 134.5 dB on TL
Tones: Not metered
Looking forward to getting new numbers with the Xcon's! I was quite impressed with my score on 5-600 watts on my LI.
Tones: Not metered
yeah that's a good score for that amount of power, cone area, and being a trunk :P
I'll be curious to see the results after you got the xcons in. Have you decided what amp you'll be using?
Vehicle: 2003 Toyota Camry
Equipment: Stock Alt, Stock Battery,4 gauge DB Link, PA Bamf 5500, Treo SSX 15 dual 1. Forgot box size and tuning
Meter placement: USACI Kick Panel
Music: Some musical
Tones: Car Freq 63 Burped a 143.7 on a TL
Sold everything but the treo and gonna upgrade everything very soon
Music: Some musical
Me too :)
Tones: Not metered
I'm using an IA 40.1, I just need to save up to get a DC power alt so I can power it properly lol. They've actually been in for a while I just don't have a meter, I'm probably hitting somewhere in the upper 140's though (pretty hard to judge though).
Tones: Not metered
sweet, how much power does the IA 40.1 make on the sub channel (or it's a monoblock one channel?)?
Tones: Not metered
It's a monoblock rated at 3600 Wrms @12v, and people say it to do anywhere between 4-5K on 14.4 volts. Oh, and it looks bad ass lol.
Tones: Not metered
Yeah there all black right? Sounds like a powerhouse :D
Vehicle: 1990 Honda CRX (if they're instantly loud, go get one yourself and replicate what people do in them)
Equipment: POS alt I get 86 amps out of, 2 Stinger batteries, one Sundown SAZ-3500d, one Sundown SA8
Music: 144.2 @ 37 hz in kick, 142 something on dash @ 37 hz (just a regular daily box, I don't mess with music boxes for it)
Tones: 152.1 @ 68 hz in kick, 148.6 @ 62 hz on the dash (a lot of testing, competition box)
Vehicle: 2003 Dodge Durango
Equipment: Stock alternator 160 amp, XS Power D1200, (2) SAZ1500d's strapped, (2) SSA Xcon 12", 4.0 cubic feet tuned to 32hz
Meter Placement: dash
Music: 143.2, Monster by Kanye West on TL
Tones: 32hz 144.4db on TL
152.1 with one 8" :)
Love that song with Nikki in it ;)
1978 Bronco
8 RE8s (box in avatar)
Sub channel of Alpine MRV-F450 (150 watts)
143+db on the Term Lab as measured by Black00....
Electrical upgrades? lol.... Not needed...
Vehicle: 2006 Mitsubishi Raider XLS 4x4 crew cab
Equipment: AQ1200D, Polk Audio MM 1040 10"(x2), 2.3 cubic foot@32hz
Music: not metered
Tones: 41hz, 135.5db
not bad for some shallow sq polk audio subs
1978 Bronco
per, or total?
Vehicle: 2002 Camry
Equipment: 2 12" BTLs, 4.2 cubes, single 6" aero 33hz, AQ 1200D
Meter placement: Legal; sealed at the dash
Music: No clue
Tones: 38 hz, 137.5 (I think my peak is much lower, didn't have enough time to test.)
1992 volvo 240 sedan
Aq 2200 at 1ohm.
Subwoofers fi bl's fully loaded two 12's 3inch coils
100amp bosch ho alt with 1red up front two yellows in the back.
Seat up with metal behind it!!!
Db's on music=136.4 sealed at the dash
Peak tone=36hz!
Box efficiency=5.25ohms lol
Power after box effciency and everything 637rms all for both drivers.
1978 Bronco
per, or total?
I believe that is total. So a whooping 18.75watts per driver before rise in impedance due to heat.
Perfect case of "you don't need thousands of watts to get loud" but it helps :P
97 Chevy Silverado "White Lightning" ...
4 Blues Car Audio 10 inch drivers - ISO Baric - dual chambered style enclosure tuned to 22 htz (80 inches of 4 inch pvc pipe for tuning)
Power by a Modified Linear Power 5002iq ... 8 ohm mono with Feedback ...
200 amp GM alt. 5 batteries ...
Best spl in competition ... USACI (kick pannel) 137.7 db @ 28 htz / 136.4 db (USACI street beat 2) - music Pink Floyd - The Division Bell ...
156.7 db @ 32 htz (USACI port wars) ...
2007 Scion tC
2 AQ2200ds
2 AQ HDC3 12s Copper
Tuned to 38hz with 56sqin of port
1 D3100, 2 D5100s 1 200A clamped alternator
146.7db at headrest with absolutely no testing or tuning, straight droppin box. No competitive tuning was insight at the time.
148.x in the kick.
166.8db port wars :)
Everything in trunk, back seats in upright position = stock.
Also-
4 AQ2200ds @0.4ohm
4 DC Level4 15s (not the XLs)
Tuned to 29hz, peak at 51hz
1 D3100, 1 D5100, Stock alternator
144sqin of port
153.4db at the headrest
157.2db in the kick
In just the 4 months this setup was in there, plastic bracket for dome light is rattling around, completely broke brackets holding the entire driver side controls(windows, door locks, etc) off, had to zip tie it back on from behind the door panel, the sun visor now makes noise and the brake pedal has come loose slightly( it's resonating, my braking is fine)
My old ride...
Vehicle: 2008 Hyundai Tiburon
Equipment: JBL1201.1, 2 Kicker CVX 10s, Kenwood comps and 6x9s, stock electrical. Nothing was tuned at all... threw in the night before a local show.
Meter placement: Passenger kick, driver door open.
Music: not metered
Tones: 143.9db, can't remember what hz.
Bassahaulic was who placed the meter in the car, he may know what tone I was on..
96 Jeep Cherokee
DD Z1, one 2nd gen BTL 12
2 old and worn out batteries
150.4dB engine off, dB Drag style.
