holley2346
Wiring Options On Amps
Well I have 2 3000D'S and the original plan was to strap them and hook them up to my 2 btl's. The problem is that the subs are d2... so if I strap them it will be a .5 ohm load per amp, correct? I've never strapped before so I'm not too sure about the process.
If this is the case and it won't work I would want to hook each amp to each sub individually and would have a 1 ohm load per amp... if I did this how would I set the gains to match eachother?
Also I have plenty of electrical behind these amps... about 800 AH of storage and 6000 CCA along with 2 dc power 250 sps.
Thanks for the help!
I would think that if you ran the two amps not strapped, a DMM would be able to tell you when they are matched. Although, I've been wrong before. lol :peepwall:
Edited by inkfx
you could just parallel the coils on the sub to get 1ohm per sub, then run the subs series and get a 2ohm total which would give you 1ohm per amp
In the sundown section of the forum there is a thread on how to strap the amps together. I have two saz1500s strapped together and its pretty easy to do. You will have a final 2ohm load. I have two d2 Xcons and they wire easy to 2 ohm. No idea on the burning up together part but they are linked together when strapped so probably.
