ssh
Calling scion tc owners
What's the cargo dimensions with rear seat up?
Fender well to fender well?
Depth from hatch opening to back of rear seat?
Height before you hit the glass?
Thank you
i dont have time right now but go into my build log and start with page 1 and keep goin thru it... til i tear everything out.
the first part of my build log is running 2 12s ported, 3 amps and 3 batts all in the back area keeping back seat in upright position...
Copy me if u want :) i dont care. It was pretty loud.
doin 146s at the headrest with no tuning for competition.. just straight daily driver throw in.
If you line your car with 2-3 layers of sound deadening like i did.. my resonance at the driver headrest is 42hz.
It also has a peak in the cabin at 34hz and another one at 23hz.
So, if u want to tune low, tune around 30-32hz so u get that 34hz peak goin crazy in the car.
If your box is too small for your subs, u can always tune in the upper 30s to get it to peak at 42hz. It's very loud there.
Thanks for the insight and advice, I'll def be reading through your log.
I'd like to keep the rear seats up, but I'll have to see what I can fit behind them...
You did 146s with 2 12s? daily power?
The most I've been able to pull off is 143db on a 40hz tone in my last vehicle. And that was with the passenger door open...
I'd like to be able to do 146db+ sealed up on music.
Trying to use efficiency of big drivers (say 2 15s, if big enough ported enclosure can fit) and ~3k.
Thanks shizz
2 15s? gona have to run nightshades or SA-15s cuz u dont have a lot of space back there...
then perhaps 12s and more power...
Still up in the air which car I'll get. I'd love to get a volvo v70, has tons of room... but finding one with semi low miles and in my budget may be a bit tricky. On the other side, it looks like I can easily afford a tc with low miles...
tomorrow i'll make a trip down to the dealership and measure out the rear cargo area and go from there.
hows your build going along?
i dont work on it when it's cold out.. so i wont work on it for a while from now
