RollinOn23z
depth of a sundown e8
i was wondering if u could help me out sundownz... i am trying to find the depth of a sundown e8 v1 from the top of the surround to the bottom of the magnet. i am doing a stealthy build and depth is a big restriction. thanx in advance
I seen that listed as mounting depth, that was the first place I checked. I would expect that to be from the bottom of the mount to the bottom of the motor/magnet... correct me if I'm wrong and if I am wrong then thank you for the answer.
Since the v1 E8's are discontinued, you probably need the mounting depth for the v2's, which is available HERE and is, according to Jacob 4-9/16" and yes, should be from the bottom of the mounting ring/flange/area to the bottom of the motor/magnet assembly.
the I have a seller with v1's... they are a shallower than the v2's which is the only reason i am considering
Since I'm the only one that read the original post to know what he is asking for, I'll also provide the answer.
5.25", thanks for playing.
How'd I find that answer? A measuring tape and actually having one to measure.
