solidcrowd
8" Bravox for HT enclosure help!
I just bought a 8" Bravox Audio subwoofer (PXW8D-2). I have a 180-240rms plate amp that I will be using to power this. I was looking to build a sonotube enclosure or just a regular ported enclosure (don't matter to me). I just need to know what size enclosure (sealed and ported) would be best for this subwoofer in the home. Space is not a concern.
If not a problem, I would like to know the optimal enclosure ported for 1 and 2 of these also.
My problem is that the lowest my amp will wire down to is 500rms @ 4ohms. I would like to eventually try it in the car, or I might just have to find another one in the future.
But back onto the main topic..It will be used for movies, but a little more for music.
Here are the Parameters:
Size (inches): 8"
Z (ohms): 1.0
Xmax (mm): 7.6
Fo (Hz): 35
Bl (T.m): 5.1
Vas (liters): 25
Qms: 4.0
Qes: 0.45
Qts: 0.40
Mms (g): 52
SPL (dB/w/m): 86.0
Levc (mH): 0.42
Krm (mohms): 1.18
Kxm (mH): 21.0
Erm :0.82
Exm: 0.56
Freq. Resp. (Hz): 30-4500
Power (max/nom): 360/180
Thanks!
